I have a leak at front pasenger side brake caliper.
Leak comes out from a piston.
When i replace the caliper...do i need to bleed all lines or just that one?
Front brake caliper leak
- misha
- Has thanked: 152 times
- Been thanked: 402 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 1506 times
- Been thanked: 3819 times
Just that one should be fine, Misha. I’ve always found it easier to start the unions with the caliper loose rather than attached. Crack the union while attached , then remove caliper. If you quickly unscrew the caliper then plug the new one in, you don’t lose much brake fluid.
If you unscrew the caliper by turning it on the hardline, you don’t have to fuss with those tough hardline to soft line junctions
Some pictures here
viewtopic.php?t=57155&hilit=1999+v70+t5&start=10
This procedure has been approved by Serbian Huskies....
Some pictures here
- C36F9711-25D2-4F7D-A35B-E21BF2DB3A70.jpeg (217.49 KiB) Viewed 319 times
- misha
Replacement caliper arrived.
I'll report back when i'm done.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Brake caliper replaced,brake line bled and since brake pads were down to just 4-5mm i replaced them too.
Performed initial bedding-in procedure and from now on i need to avoid heavy braking for around 300-500km.
I bled the line with engine running...i hope i didn't messed something up.
Some say without engine running...some say with engine running.
I don't see the difference with or without engine running,since principle is the same.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 1851 times
- Been thanked: 1712 times
The advantage of engine running is you get the servo boost in the line which may help move any air pockets. You can do the same with a pressure bleeder without the engine running.
- 15 Replies
- 5253 Views
Last post by wizechatmgr
- 43 Replies
- 7897 Views
Last post by TRuck
