989805 and 989806 bulbs
xnRS
Year and Model: 1994 Volvo 850 2.5T5
Has thanked: 7 times
Been thanked: 5 times
Post by xnRS »
Hey everyone, I wanna swap out instrument cluster bulbs, including warning lights. I found out, that i need 989805 and 989806 bulbs, and by the bulbs guide 989806 is Osram 2721MF, while 989805 is unknown. Did anyone found an answer for this one ?
Also, can I swap out bulbs without plastic body, just bulbs, as they are much cheaper, then the ones with plastic body.
1994 Volvo 850 T5
Italian spec, originaly 2.0 T5, early facelift with OEM RIP kit, early dash buttons and etc.
Previous Owners swapped 97' B5254T
Mods: Titan R17 Rims, Japanifold, Motronic 4.4 with S70R Tune
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Nope...they come as a unit.
On S,v,c,xc70...bulbs are replaceable.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
xnRS
Post by xnRS »
hm, but i found 2721 by Osram, which is lamp, without the socket
1994 Volvo 850 T5
misha
Post by misha »
On 850...only lamps that can be replaced and keep the old socket are main big laps.
Little lamps can only be replaced as a unit(only with socket).
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
xnRS
Post by xnRS »
Ok then, as i got
989805 - 2721MFX
989806 - 2721MF
1994 Volvo 850 T5
Has thanked: 1857 times
Been thanked: 1718 times
This kit in US has bulbs and the odometer gear.
https://www.ipdusa.com/products/4709/85 ... 800-109979
If you click on this link you can magnify the smaller bulb where you can see it is soldered into the cap:
https://parts.volvovilla.com/p/Volvo__8 ... tensionID=
A lot of the other small bulbs used on the dash like the switch illumination can be replaced just as the bulb and fitted into the old holder.
xnRS
Post by xnRS »
yea, not very nice design. Only replace whole unit, or solder in, somehow, new lamps. I think i'll go with 2721MF for 989806 and MFX for 989805
1994 Volvo 850 T5
