- Has thanked: 1834 times
- Been thanked: 1709 times
Just got a text from my friend with the red V70. Some A??hole has just backed a large truck into the rear of her car. Damage to rear bumper and large dent to the LHS of the tailgate. The idiot was driving a large cube truck he had borrowed and tried to turn it around without looking behind himself!
- Has thanked: 1497 times
- Been thanked: 3809 times
Free repair $$$$$ !scot850 wrote: ↑30 May 2022, 14:49 Just got a text from my friend with the red V70. Some A??hole has just backed a large truck into the rear of her car. Damage to rear bumper and large dent to the LHS of the tailgate. The idiot was driving a large cube truck he had borrowed and tried to turn it around without looking behind himself!![]()
yanga001
- Has thanked: 59 times
- Been thanked: 110 times
started the turbo car, it still purs although i need to find time for the brakes on it. Checked ECT on my car and it seems the readings are well within spec. Checked for my spare maf but i could not find it. I think i already have it kicking around home somewhere. Will try the maf cleaner on it and swap it and see how it runs. Mechanic said it might help with the odour. The exhaust seems its nearing end of life so i might have to get quotes for a new installation.
2008 S60 2.5T Auto (Sold)
- Has thanked: 304 times
- Been thanked: 517 times
$3 for a 4 or fewer terminal relay, $6 for 5+.
yanga001
Rebuilt my rear windshield wiper assembly again. User proper silver grade antiseize instead of crappy tire spray on lithium grease. Thing spins well and hopefully will not seize again. Thinking about doing the same treatment to my front wipers as my rear now spins faster then the fronts!
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 128 times
I'm not trying to be a downer, but anti-seize isn't meant as a lubricant for moving parts. Unless you've got a product that's not your ordinary anti-seize?yanga001 wrote: ↑30 May 2022, 21:02 Rebuilt my rear windshield wiper assembly again. User proper silver grade antiseize instead of crappy tire spray on lithium grease. Thing spins well and hopefully will not seize again. Thinking about doing the same treatment to my front wipers as my rear now spins faster then the fronts!
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
yanga001
it came under the advice of my mechanic. From what i gather on the product page it says it can be used on rollers and is marine grade so ill report back what i find. The white lithium grease seized in 2-3 weeks. Hopefully this stays longer.454cid wrote: ↑30 May 2022, 22:51I'm not trying to be a downer, but anti-seize isn't meant as a lubricant for moving parts. Unless you've got a product that's not your ordinary anti-seize?yanga001 wrote: ↑30 May 2022, 21:02 Rebuilt my rear windshield wiper assembly again. User proper silver grade antiseize instead of crappy tire spray on lithium grease. Thing spins well and hopefully will not seize again. Thinking about doing the same treatment to my front wipers as my rear now spins faster then the fronts!
https://www.permatex.com/products/lubri ... cant-4-oz/
- ZionXIX
- Has thanked: 64 times
- Been thanked: 194 times
Being from Texas I don't have to use antisieze often but when I lived in the carribean it was a requirement. I have been guilty of using it as a mild lubricant.
Got my repair kits for the 2 x P80 load covers I have that were broken in the house move 2 1/2 years ago. I was looking a the Skandix parts but at $50 Euro each kit and 55 Euro shipping it did not make sense. Found another one from Slovakia and the seller was very helpful:
https://www.ebay.ca/itm/282971919483?mk ... nl%3Dmkcid
I just need time to try and do the repairs which look fairly straight forward, biggest issue is getting the spring tension of the cover right! If I figure it out I will post a how-to.
After helping my young friend find someone to fix her bruised V70 that a guy in a large truck backed into while trying to turn a loaned truck around, I decided it was time to finally fit the 4Runner's 'summer' rims and tires that have been waiting for nearly 4 years! House renovations, garage building, moving and stuff in storage have put this on the back burner. The tires were brand new Michelin LTX's (expensive) and the rims were 6 months old used but like new. Hopefully the tires are not suffering from standing on racks for so long!!
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 250 times
- Been thanked: 77 times
Cool, I'd be interested how that cover repair turns out. The plastic mounting pieces on mine are falling to bits/crumbling since I took it out.
850 T5-R '95 auto
