Rough idle
cmbfoto
- Year and Model: 99 S80 02 XC70
- Has thanked: 11 times
Rough idle
My 01 V70 2.4t has a very rough idle when starting. After 2min the idle smooths out. I’ve changed out the MAF with a test unit still no change. No check engine light but did pull a code 6806. I unplugged the power to the TC Valve and no change. Got me scratching my skull.
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 126 times
- Been thanked: 116 times
Only time I had a rough idle was during my vacuum leak and bad throttle body conundrum. By rough idle do you mean a hunting idle, high idle, or low idle?
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- Has thanked: 1503 times
- Been thanked: 3817 times
Very typical of rotted vacuum hoses under the intake manifold where you can’t see them.
Gory pictures…go ‘Cuse!
- BFBDE705-FF59-435C-93EB-46BED8BEFF1A.png (2.21 MiB) Viewed 314 times
cmbfoto
My son bought a 04 V70r and got side tracked from the 01 V70
Ok sprayed half a can of brake cleaner over the vacuum lines,Turbo connections and injectors. No difference. Unplugged the Mass Air Flow Sensor. Things calmed down a bit idle smoothed out. Plugged the sensor back in idle was still smooth. The fan kicked on witch I found odd. The temp gauge was in the middle I found that odd. Used my surface temp gun at the thermostat read 150° the lower hose read 120°. Hmmm that’s not right with the fan running
