Yeah, those diagrams I posted are only for -98, I should have noted as such.abscate wrote: 26 Nov 2017, 08:53 Do you see the problem with the 1999- short belt routing? The alternator reverses direction of rotation so that a free wheeling pulley will no longer make juice. You could get home during daylight from an hour or two and a good battery
The Zexel AC compressor also mounts differently than pictured. 4 Long M10 x 150? Bolts run front to back into four mounts on engine vs the transverse bolts pictured above
P80 (-1998 , 1999-2000) Serpentine belt path route diagram picture
- Has thanked: 312 times
- Been thanked: 818 times
- Has thanked: 1613 times
- Been thanked: 4078 times
I just created the thread to make a searchable topic for anyone in the Forum to find their routing, even the children of the “bastards “
In pictures, old thread
Two things happened in 1999 that complicate
1 alternator rotation direction is reversed
2 the pulley clutch was added, so that the alternator is only spun in one direction internally.
If you short belt, a 1999, you thus won’t get alternator charging.
And reviewing maintenance and roadside fix procedures with Abby this week, I discovered the 1999 s/V70 owners manual has the 1998 *wrong* serpentine belt diagram in the service section!
Page 128 from the 1999 owner manual….fail!
- 13 Replies
- 28743 Views
Last post by Clemens
- 10 Replies
- 1544 Views
- 29 Replies
- 2714 Views
Last post by MarinerMan
- 1182 Views
Last post by skaupert
- 16 Replies
- 3893 Views
