Front ABS Sensor cable replacement
- Has thanked: 1507 times
- Been thanked: 3824 times
Dave, your 2000 has a connector up on the strut towers tyst let you replace the sensor and wire by plug in.
-1998 you have to repair the loom
1999-2000 ABS sensors come with connectors
- davep84
- Year and Model: 2000 S70 GLT
- Been thanked: 9 times
Thanks for the quick reply. This problem is on my 98, not the 2000 so I'll try to repair it. Looks like I'll need to source some sort of bullet connector to fit over the male terminal on the abs sensor. Or could I use the later style abs sensors and splice them in to existing wiring? Thanks
