MVS Readers,
As I pointed out I wasn't satisfied with the performance of the Overdrive (Clutched) Pulley that I purchased. It had stopped working. After I removed it I was able to get it to ratchet but it wasn't smooth and it would get stuck and stop working. I do have this identical part on my LR2 with the Volvo 3.2 and it works perfectly.
So as ABSCATE correctly pointed out you do often get what you pay for.
And because I was in there I also decided to get a new Tensioner
$81.95 --- 5350195100 INA Overdrive Pulley
$64.78 --- 38495 Gates Tensioner
Total = $146.73
Note: if you pay Volvo MSRP for these parts the cost would be $440.48
Here is the cost update
5/9/2022 cost update
11/21/2018 Purchased S80 125,000 miles
05/09/2022 Cost Update 151,000 miles
Ownership duration 3 years 6 months
Ownership distance 26,000 miles (without COVID this would be over 50,000 miles)
Total Vehicle Cost (excluding, wheels, tires, fluids and filters)
$3400 --- Depreciation (Purchase price $7400 - Present value $4000)
$62.53 --- (31401556) --- Booster O-rings
$40.35 --- (DENSO 5344) --- Sparkplugs
$58.28 --- (LR006071) --- Thermostat
$00.66 --- (LR001505) O-ring for 30713530
$24.29 --- (30713530) --- Coolant hose
$68.85 --- (31272677) --- Oil Filter housing
$18.92 --- (LR006076) --- Idler pulley
$18.92 --- (LR006076) --- Tensioner Pulley
$08.97 --- (PK060473 CONTITECH) --- Aux Belt
$112.70 --- (LR021634) --- Motor Mount
$23.24 --- (30680474) --- Torq Mount
$15.76 --- (UD1306) --- Front Brake Pads (Amazon close out price, typical price is ~$75)
$523.23 --- AC repair
$43.37 --- Overdrive pulley ProParts Sweden 28436803
$323 ---- Radiator (Prem Air type)
$281 --- Radiator Fan (Siemens / VDO)
$34.4 --- (31272732-MFG14) BOSCH Fuel Pressure Sending unit
$11.61 --- (31300263) B+ Battery Clamp
$00.00 --- Loaner Battery from the Land Rover (Note: it is slightly too large and the cover only latches on one side)
$156.00 --- Mirror repair
$120.00 --- H8 GTR Ultra LED 2.0 bulbs
$06.00 --- Brake light bulb
$02.05 --- (30658215) Receptacle Housing for the MAF Sensor
$09.43 --- (31214625) Volvo Emblem
Total $5577
PS I let my Nephew borrow the S80 for a few days and he commented that it is a really nice car. And I must admit that I agree it is a very good car.
$10,000 S80 Challenge Topic is solved
The $10k S80 Challenge
Steve H
- Year and Model: 2008 S60 2.5T & XC70
- Has thanked: 6 times
- Been thanked: 10 times
When you update your cost can you show your starting mileage on the car when you purchased it and the mileage as of your cost update? Thank you. Great Information provided to the forum.
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 115 times
- Been thanked: 185 times
MVS Readers,
I started this thread to show the cost of a ~10 year old P3 Volvo.
The cost that I am tracking is Vehicle cost which I am trying to keep under $10K. I haven't been tracking the cost of Taxes, Registration, Oil changes, Brakes, Tires or Fuel. I did this because these cost vary significantly depending on where you live and I wanted this thread to be useful to people that don't live in my Zip code.
Having said that I am going to share something that my son sent me.
My Son is driving from Northern California to Southern California and he took a picture of the dashboard that I thought you might like to see.
The picture was taken about 190 Miles from my house and it is mostly highway.
Not a bad result for a 12 year old car with 150,000 miles
The EPA highway rating is 27 MPG so lets just say that the S80 can still meet that rating
Thanks
Paul
Thanks
Paul
- Has thanked: 1506 times
- Been thanked: 3822 times
28 mpg in a big luxury Tank….excellent.
Fixed this for you
($3400) --- Depreciation (Purchase price $7400 - Present value $4000)+ Covid appreciation of $6800
Fixed this for you
- pgill
Loyal MVS Readers,
Please stand by for my next updates.
I've ordered the parts but it will take a week to get here
A preview
- Driver door threshold trim piece (this was slightly damaged when I bought the Car and now it is completely broken)
- Front Wheel Bearing (right now the plan is to change one and see if the Tire noise improves)
I did reach out to the Land Rover board to get their opinion on the wheel bearing. If you are interested in their comments take a look here https://www.freel2.com/forum/topic38275.html
I posted my question over there because their suspension is very similar to my 2010 S80 and they seem to break a lot of wheel bearing.
Please stand by for the updates
Thanks
Paul
A preview
Thanks
Paul
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 113 times
- Been thanked: 115 times
Our 2013 XC90 with close to 160,000 miles has front wheel tire noise. It was due for a tire rotation, and the tire tech pointed to front driver tire for its uneven wear; suggested a wheel alignment check. We run our cars on Pirelli; the tire noise disappeared after the rotation; it was in early May.pgill wrote: ↑13 Jun 2022, 16:27
For diligence, I scheduled an early morning wheel alignment at a local Firestone (our go to shop for alignment for many years), and the tech said alignment is good, it may be the suspension that is causing the tire wear. These tires are more than 4 years old with 30,000 miles on.
Fast forward, now the intermittent tire noise is back. The noise is well audible over the newly paved asphalt; and a minor pull to right.
All suspension is original. I've started to collect suspension parts. Local Volvo had a 20% off day so I picked up a set of front wheel bearing for $160 each.
- pgill
MVS Readers,
I haven't posted for a couple weeks.
I am still fighting the vibration at the front end of my S80.
Here is what I've done.
1. replaced the front right wheel bearing
2. replaced the front left wheel bearing
3. had the wheel balance checked at my trusted tire store (and discussed possible alignment issues with the technicians)
Here is where the story gets convoluted. After replacing the wheel bearing things seem improved but still not as good as it was two years ago. Replacing the bearing is time consuming and I was anticipating a better outcome.
So I went to the tire store to get the balance checked and it wasn't perfect but it didn't take much bring it into specification (this is the same store that balanced these tires originally and I use them for all of my cars). After the minor balance change the vibration seemed about the same.
Note: the front tires are worn strangely, if you run you hand around the tire clockwise it is reasonably smooth however counterclockwise has ridges that catch your hand. The technician at the tire store told me that a small balance problem and/or an alignment problem won't cause that to happen. He indicated that I need Struts/Shocks.
The ride is really nice on the S80 so I have resisted changing the Struts. But I trust the Technician at the Tire store and so you can guess what I recently ordered.
The tool that I bought on EBay to remove the wheel bearing worked well with the exception that I had to install some spacers to press the new bearing in (I used the pins that came in the kit but they were too long so I had to lay them flat instead of inserting in the holes)
For removal the tool worked as expected.
Some pictures.
Note: the old Jack handles and the 1/2 craftsman ratchet that I very rarely use (it is 30 years old)
Here is the new bearing installed
Take care
Paul
PS the front brake rotors we getting rather worn out so I decide to replace them while I was in there. Amazon will lower the price of their inventory if it doesn't sell so I got two extremely high quality rotors for an amazing price. List price is $155 for the pair and I paid $29. EBC Brakes RK1500 RK.
Some pictures.
Take care
Paul
- pgill
MVS Readers,
I've been busy so I haven't had a lot of time to work on the Volvo.
I do have a few updates.
1. I started this thread to chronicle the S80 and see what it would cost me (Repairs) and my son (Fuel) and to see if it could be done inexpensively.
2. My Son bough a new car, so maybe I should close this thread.
3. Note: I still have the S80 and my niece is using it and I am still maintaining/repairing it. So maybe the thread continues until I sell.
4. Let me know what you think.
With that in mind here is my latest repair.
I purchased new shocks for the rear (Bilstein B7) and removing the old shocks wasn't too hard. I did use air tools to make it significantly easier. Doing this job without an impact driver (Pneumatic or Electric) would be problematic for the bolt that holds the lower mounting bushing. I did try to remove it with a breaker-bar but the S80 wasn't high enough for me to get a good angle so I gave up. If I had a lift then getting a good angle wouldn't have been a problem. My garage is full so I replaced the shocks on the street in front of my house.
I am still dealing with strange Tire wear and the Tech. at the tire store that I use indicated that I had a Shock/Strut problem and not an alignment problem.
When I disassembled the old shocks to get the dust cover, spacer, and upper mount I was very surprised by what I found. The first on came apart as expected. For the second shock holding the bottom and pressing the impact gun on the top nut collapse the shock. For anyone unfamiliar with this the shocks are filled with Nitrogen under high pressure to prevent the oil from foaming during use and if the Nitrogen leaks out then you get exactly what I found.
Special Thanks to the Technician at the Tire store that pointed me in the right direction.
Its really hot here during the day so I did the work as the Sun went down and I didn't have time to take any pictures.
Take care
Paul
Take care
Paul
- pgill
MVS Readers,
Something a little less technical today.........enjoy
It rarely rains here in Cali so when it does I take advantage of the free rinse water.
Full disclosure I did wash and wax he car
As can be expected here.........the rain returned
