98 V70 Turbo - Crank but no start
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Re: 98 V70 Turbo - Crank but no start
Post by Goupil »
It's leaking where the pipes enter the thermostat. One of the hose is starting to leak (replaced the other a few years ago), so I did the lazy thing and grabbed the whole thermostat/hose assembly from the donor car :mrgreen: I'll check the clamp straightness on the bench if I want to drop an engine back into the C70
Once I was done with that and a few other things, I started the car for more than a few seconds and noticed it was running like shit.
Checked a few thing, started thinking it was running on 4, went to unplug the first spark plug wire and it felt easy, very easy... Welp that's a new one ! :shock:
Dropped a spare plug in there and now it's running great again !
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 131 times
Post by 454cid »
Wow, that's weird!
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 1857 times
Been thanked: 1718 times
It may have been dropped at some point and the ceramic is easily cracked. Been many years but had a brand new Bosch plug that was cracked when removed out of a sealed box. Rare, but happens. Bad luck for that to happen when you were already working on your challenges!
I found some pictures of the oil cooler thermostat issue I had. Not great pictures but will give you and idea of the issue:
Engine Oil cooler pipe seals at thermostat
1998 Volvo Oil Cooler Thermostat housing 001.JPG (209.3 KiB) Viewed 177 times
These were brand new 2nd set of oil cooler pipe seals fitted by the dealer. They were shredded by hard old oil deposits
Dried hard oil residue
1998 Volvo Oil Cooler Thermostat housing 002.JPG (214.91 KiB) Viewed 177 times
Not a great picture, but you can see the hardened ring of old oil that was shredding the new seals.
I removed the oil thermostat and carefully scrapped the old oil deposits out with a sharp metal edge taking care to not score the seats for the seals.
Also reversed the clamp after straightening with a hammer.
