Rad Hoses Blowing Apart
Third generation Volvo V70 wagon and XC70, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
Doc67
Year and Model: 2008 XC70
Post by Doc67 »
Just wondering if anyone has any input on this. It happened on my 2008 XC70 3.2. My upper rad hose blew apart a couple of weeks ago. So, I replaced it with another one that I had. It lasted a couple of days, before it split. I replaced it again and it split again. So now, I know that its an over pressure situation. I ordered a new hose, thermostat and rad cap. When I pulled the old thermostat off, it came out in pieces, so obviously it was done. But, after looking at it, it appeared to be stuck wide open. This seems to be counter intuitive to me. If it was wide open, could it be responsible for an over pressure situation? Why did the cap not blow off the excessive pressure? Anybody have any ideas? FYI, I put it all back together with the new parts and we will see if it happens again.
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 115 times
Been thanked: 185 times
Post by pgill »
I would do what you listed.
And I would caution you to use original parts for the Thermostat and the Hoses.
Aftermarket Thermostats are know to fail early (I've seen the video but I couldn't determine the manufacturer of the failed part but it was definitely not a Volvo or Land Rover part)
If it is cheaper you can use Land Rover parts. The 3.2 was built at a FORD plant in the UK and installed in several Volvo's and the LR2.
Typically Volvo is cheaper but not always.
Take care
Paul
2010 S80 (with a Land Rover Thermostat)
2008 LR2 (with Volvo coolant hoses)
PS the pressure in the system should be roughly equal everywhere unless you restrict the flow. A broken Thermostat could restrict the flow enough to cause the pressure in the upper hose to fail. You can check the flow from bleed pipe on the cylinder head to the reservoir. If this spraying like a fire hose then you have a problem it should flow like a water fountain (Drinking fountain?)
Some pictures https://www.freel2.com/forum/topic32245.html
Doc67
Post by Doc67 »
Turns out that the thermostat broke apart and all of the pieces were causing a blockage. Replaced the thermostat and it is good as new again.
pgill
Post by pgill »
Very nice.
Thanks for the update.
You have fixed letter A
Typical repairs for high mileage 3.2
A) Thermostat – replaced mine at 10 years (also replaced two coolant hoses)
Here is the complete list
https://www.freel2.com/forum/topic32504.html
Take care
Paul
