Parts brands - OE Volvo, trusted aftermarket, and bad
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
Which aftermarket parts brands do we trust and which should be avoided? Which brands make the parts that Volvo sells under their brand and is there any difference between theirs and Volvo? Which parts are better bought as Volvo brand instead of any aftermarket?
Please reply with any:
- Information about which companies make specific parts sold under Volvo brand.
- Experiences you've had with brands and parts, good or bad.
- Brands and parts to add.
- Corrections, changes, etc.
I will compile all submitted opinions into the list below.
The following is a list of brands with the categories and parts they make. This list started from browsing FCP for a 2000 V70 so the categorization is theirs. Additional brands and parts have been added based on forum user comments. The raw data in Excel (from the initial list from FCP) is attached, grouped in by brand or by category in separate tabs.
Brands I'm most curious about:
Febi Bilstein, Hutchinson, Lemforder, Meyle, Nissens, Rein
Specifically for gaskets, o rings, seals - Corteco, CRP, Elring, Victor Reinz
Categories by brand:
Aisin:
Cooling System - Water pump
Akebono:
Brake - Pads, rotors
ATE:
OE Volvo, per FireFox31.
Brake - Pads, rotors, fluids, hoses, master cylinder, sensors
Beck Arnley:
Engine - Coils - Avoid. They rebox parts from other, unknown vendors, per erikv11 in 2014.
Beru:
Engine - Spark plugs
Bilstein:
Suspension - Shocks, struts
Bosch:
Air Intake - Switches
Brake - Pads
Engine - Alternator, mass air flow sensor, sensors, spark plugs, starter, valves, voltage regulator
Engine - Coils - OE Volvo, per FireFox31.
Fuel System - Fuel filter, fuel pump
Steering - Power steering pump
Bougicord:
Engine - Spark plug wires
Brembo:
Brake - Rotors
Bremi:
Brake - Sensors
Cardone:
Steering - Rack - Avoid!! Three reports of locking up weeks after install, per abscate.
Centric:
Brake - Calipers
Drivetrain and Axle - Wheel bearing
Continental:
Engine - Belts
Corteco:
Air Intake - Gaskets
Brake - Hoses
Drivetrain and Axle - Seals
Engine - Engine mounts, head gasket, o rings
Engine - Seals - OE Volvo, per scot850
Exhaust - Gaskets
Suspension - Mounts
Transmission - Seals
CRP:
Cooling System - Clamps
Engine - Seals, valves
Fuel System - Clamps, vacuum hose
Delphi:
Fuel System - Fuel pump
Denso:
Engine - Crank sensor
Exhaust - Sensors
ECS Tuning (retailer):
Service kits contain a mix of OE and junk parts, per BlackBart.
Elring:
Cooling System - Gaskets
Engine - Head gasket, seals
Fuel System - O rings
Empi:
Drivetrain and Axle - Axle boots - Avoid! Rubber was terrible and barely lasted 6 months, per scot850.
FAE:
Engine - Cam sensor
FAG:
Febi Bilstein:
AC and Climate Control - Blower motor
Brake - Parking brake cable
Engine - Head bolts, pulleys
Suspension - Bump stops, control arms, trailing arm links
Suspension - Mounts - Good after two years, per Goupil.
Gates:
Cooling System - Fluid tank caps
Engine - Belts, pulleys
Fuel System - Gas cap
GKN:
Drivetrain and Axle - Axle boots - OE Volvo, per FireFox31.
Glyco:
Engine - Main bearings
Hepu:
Hutchinson:
Engine - Engine mounts - Good after two years, per Goupil.
INA:
Engine - Pulleys, tensioners
Suspension - Mounts
IPD:
Service kits may contain inferior parts like URO brand, per scot850.
Suspension - Sway bar and components - Poor quality, per scot850
TCV (Transmission Control Valve?) - Fragile design, per scot850
Jurid:
K&N:
Air Intake - Air filters - Oiled filter may affect thin film MAF, per 454cid.
KaE:
Fuel System - Fuel pump relay - Avoid. Under 12 month life, per abscate.
Koni:
Lemforder:
Steering - Tie rod boot
Suspension - Control arms, mounts, sway bar links
Lesjofors:
Suspension - Springs - Thinner than OE Volvo, per jreed.
Luk:
Transmission - Flywheel bolts (single mass M56) - Might be OE Volvo, per Goupil.
Mahle:
AC and Climate Control - Air filters
Cooling System - Thermostat
Engine - Oil filter
Mahle Behr:
AC and Climate Control - Blower motor, heater core
Cooling System - Radiator
Engine - Oil cooler
Mann:
Engine - Oil filter
Meyle:
Brake - Rotors - Good coating, per 850oldschool.
Exterior Body - Washer fluid pump
Steering - Tie rods and boot
Suspension - Control arms, sway bar links, trailing arm bushings
Nissens:
AC and Climate Control - A/C system, heater core
Engine - Oil cooler
NSK:
A Japanese manufacturer of similar quality to SKF and INA, per 850oldschool.
Pagid:
Pentosin:
Brake - Brake fluid
Cooling System - Antifreeze
Transmission - ATF
Pierburg:
Air Intake - Air pump, valves
Fuel System - Fuel rail regulator - OE Volvo, per FireFox31.
Transmission - PNP switch, retainers
Pro Parts Sweden:
Only use for non-critical applications, per scot850.
Brake - Hardware
Drivetrain and Axle - Hardware
Engine - Engine mounts, hoses, main bearings
Exhaust - Exhaust manifold, hardware
Exterior Body - Lights
Interior Body - Relays
Interior Body - Tailgate repair kit - Better than Volvo and includes clips, per scot850.
Suspension - Bump stops, hardware
Rein:
AC and Climate Control - A/C evaporator, o rings
Cooling System - Hoses
Steering - Hoses
Suspension - Subframe mounts
Sachs:
Clutch and Flywheel - Clutch
Suspension - Mounts, shocks, struts
Santech:
AC and Climate Control - O rings, switches
SMI:
Steering - Rack - OE Volvo, per FireFox31.
Stabilus:
Exterior Body - Tailgate strut
Textar:
Brake - Pads, rotors, shoes
TRW:
Steering - Power steering pump, rack, tie rods and boots - OE Volvo, per FireFox31.
URO:
See URO parts thread with input from URO.
Avoid everything except air guide, per scot850.
Engine - PCV rubber parts - Avoid! Multiple reports of 3-6 month life, per abscate.
Exterior Body - Under-engine air guide - Reasonable quality and price, per scot850.
Vaico:
Engine - Engine mounts, PVC oil trap
Steering - Power steering fluid tank
Valeo:
AC and Climate Control - Heater core
Victor Reinz:
Engine - Head gaskets, o rings, seals
Exhaust - Gaskets
Zimmermann:
Brake - Rotors
Part brands.xlsx
(11.24 KiB) Downloaded 329 times
FireFox31
Has thanked: 1505 times
Been thanked: 3817 times
Do we add in the bad boy reports , too?
Cardone steering racks - three reports of locking up weeks after install
URO Pcv rubber parts - multiple reports of 3-6 month life
KaE fuel pump relay - under 12 month life
Aftermarket p80 battery cable - less than 12 month life
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 129 times
Post by 454cid »
I would not want an oiled K&N filter in front of our thin film MAF since they don't clean well (so I've read), I've heard of them messing with hot-wire MAFs, but at least those are readily cleaned.
Thanks for compiling the list. With Volvo there are lots of companies/brands that I have not heard of.
I'd like to suggest Bougicord for spark plug wires.... even though my first box was mislabeled.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 1847 times
Been thanked: 1710 times
Marvelous list but I would like to disagree on a few items, hope you don't mind!
Bosch - Please add MAF
EMPI CV boots - I would never use them!! Rubber was terrible and barely lasted 6 months!!
Corteco - Engine Mounts/brake hoses/suspension mounts? I have never seen them but if they exist are they good?? Engine seals are OE and only ones I use that are not Volvo OE boxed items. Suspension - Volvo or Hutchison. But good to know there may be other options for this stuff as Volvo continue to NLA parts.
Pro-Parts Sweden - Nothing critical! Only thing I have had which was good was the tailgate repair kit for P80 V70. It is actually better than the Volvo kit as that does not include the clips and is x 1/3 the price!!
URO - They make an undertray/air guide for the P80 and is reasonable in quality and price. That is the only thing though! LoL!
I think the time you have taken to make this list for us all is much appreciated. It is helpful for us all and heck, even old guys like me can learn from this!
Many thanks,
FireFox31
Post by FireFox31 »
abscate wrote: 19 Jul 2022, 04:25 Do we add in the bad boy reports , too?
Yes, please. Reply with any experiences you've had or reports you've heard.
I started this list because it seems there are trusted brands that I've never heard of, like Hutchinson for engine mounts. Then there are brands like Febi Bilstein, Lemforder, Meyle, Nissens, and Rein which make lots of parts but I don't know if they're actually good. Let's get a consensus to help us all make better purchases and avoid part failures.
FireFox31
Made sticky so we can find it easily to fill out.
Destined for links to bothVRD and Major Topics
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
I've had a Febi lower engine mount (the one under the timing side) and a Hutchinson gearbox mount for two years, they seemed fine when I took the engine out last month. Cant remember which but I've used a few Febi seals over the years without issues as well.
Oh and my subframe bushings are from Febi as well
I bought Luk flywheel bolts (single mass M56) and they looked a lot like the OEM volvo ones.
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2654 times
Been thanked: 1248 times
Post by matthew1 »
Since we're on the subject, here's the infamous URO parts thread where URO responded, defending its products.
I'm not judging, just reporting. URO, if you'd like to post here again in any capacity, please do.
Also -> Amazon link
454cid
Post by 454cid »
matthew1 wrote: 20 Jul 2022, 15:46 Since we're on the subject, here's the infamous URO parts thread where URO responded, defending its products.
I'm not seeing the connection between UroTuning and URO Parts after visiting each website.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
matthew1
Site Admin
Post by matthew1 »
454, you're right. Thanks for your post! I've edited the links to point to the right place.
Also -> Amazon link
