2007 xc70 So what would cause brakes to be down to the floor? They say my brakes are fine, Now
Iluvvolvos
Year and Model: 2007 xc70
Post by Iluvvolvos »
The poor they’ve ordered from my brakes because my brakes are down to the floor is a master cylinder, but last time they said that the master cylinder was fine and ie brakes for doing the exact same thing
Has thanked: 1505 times
Been thanked: 3818 times
If the fluid is disappearing it is going somewhere. They can leak into the brake booster unseen but a new master cylinder would fix that
Puzzled
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
For the brake petal to go to the floor when you step on it, a few things must have happened:
    1. There is no fluid in the brake fluid tank. Check the level on the outside or remove the cap to see the level.
      2. There is a large leak at the master cylinder and the fluid is not getting pushed to the wheels. A leak at the master cylinder may be under the dash on under the hood at the master cylinder.
        3. There is a large leak at one of the wheels. You should be able to see a wet area on the inside of the wheel.
          4. There may be a leak in one of the brake lines. This is unlikely unless a brake hose is leaking or a brake tube has been damaged by impact.
          If you find there is no brake fluid, you must find the leak and repair it. Just adding more fluid is not safe. It will leak out again and you will not have brakes.
          br0dy519
          Year and Model: 2004 XC70
          Has thanked: 126 times
          Been thanked: 116 times
          Post by br0dy519 »
          vtl has mentioned dealer required to bleed air from ABS. Is that something we can do from vida? Curious about that.
          04s60 2.4
          04xc70 2.5t
          vtl
          Year and Model: 2005 XC70
          Has thanked: 114 times
          Been thanked: 606 times
          Post by vtl »
          br0dy519 wrote: 03 Aug 2022, 17:54 vtl has mentioned dealer required to bleed air from ABS. Is that something we can do from vida? Curious about that.
          Absolutely. Trigger inlet/outlet valves of the line you're bleeding with Mityvac or vacuum pistol.
          Well, pumping a pedal may actually work as well. I just was doing it with a pistol, saw a few huge bubbles escaping from one corner. Squishy brakes were bothering me for years in that car. Not a single problem with the brakes linearity after bleeding the ABS.
          Has thanked: 1850 times
          Been thanked: 1710 times
          Your brake pump has failed.
          vtl
          Post by vtl »
          scot850 wrote: 04 Aug 2022, 17:31 Your brake pump has failed.
          Why? With no engine boost, the brake booster still gets vacuum from intake manifold. Under boost the brake booster has enough vacuum capacity for 2-3 brakes. When it runs out of vacuum, the pedal becomes very hard.
          br0dy519
          Post by br0dy519 »
          I ran a car without the brake booster pump for 3 years before I realized it had failed. So yes, agree with vtl. Most Likely a hydraulics fluid issue here.
          04s60 2.4
          04xc70 2.5t
          jonesg
          Year and Model: 2004 V70
          Has thanked: 69 times
          Been thanked: 481 times
          Post by jonesg »
          I had a Ford truck with same problem.
          There was a big air pocket trapped in the master cyl.
          I pulled it off and bled it on the table.
          People have success using a turkey batter and small tube.
          A big truck mechanic told me he just sucked it out with a straw and spit it out.
          June
          Has thanked: 523 times
          Been thanked: 261 times
          Post by June »
          When you say "goes to floor" do you mean no brakes, petal goes to the floor without resistance? If a long petal travel before braking actually happens, than this is normal for P2 of that Era. My 04 S80 brakes are completely Volvo, only serviced by Volvo dealership. if I push hard enough while at a light it can come so close to the floor I cannot push the other foot toes under the petal. Higher models like my T6 and likely your XC are equipped with EBA (Emergency Brake Assist). During a panic stop It measures the speed you push the petal to determine a panic stop is in progress. This requires petal travel for the position sensor to operate. June
          My Volvo cars owned
          1989 740 GLT ordered
          1996 960 ordered
          1998 V70 GT dealer stock car
          2002 S80 T6 ordered totalled
