Vida CEM swapping
oscilloscope
Year and Model: 2005
Has thanked: 27 times
Been thanked: 11 times
Post by oscilloscope »
T5Luke wrote: 01 Aug 2022, 16:29 I have both and on both of them the same code works. So have fun with it...
Ok took the plunge and bought it.
alevol
Year and Model: 2005 S60
Has thanked: 6 times
Been thanked: 3 times
Post by alevol »
4.1 works fine.
oscilloscope
alevol wrote: 02 Aug 2022, 02:28 4.1 works fine.
Thanks
oscilloscope
We have lift off. Its arrived :D
When My son goes to bed ill have a good look at it.
jaywats
Year and Model: 05/06 s60r
Has thanked: 14 times
Post by jaywats »
ZRimaZ wrote: 12 Jun 2022, 01:12
vtl wrote: 11 Jun 2022, 16:49 It seems my repaired alarm siren is again leaking and again draining the main battery. I want to throw it away, the car is never locked anyways. Don't what to see the immobilizer warning message on every start, though. What are my options? Is it a bit toggle in CEM's car config?
I may have finally put the whole pin cracking project at use ;)
You have to remove alarm in cem config and after - disconnect siren. If you have cem flash, send it to me, i'll remove alarm from config ( in case if you do not know, how to do it ;) )
Hey I'm stuck on the same thing too, it's next on the list. can you share what needs to be changed on CEM-H 30765148?thanks!
P2 - 06 S60 2.5 || 05 S60 2.5 || 02 S60 2.3
ZRimaZ
Year and Model: XC60 MY2016 3.0 T6
Has thanked: 23 times
Been thanked: 13 times
Post by ZRimaZ »
Send your flash to me, I'll do it
Have a nice day,
ZRimaZ
oscilloscope
folks , so I'm trying to locate the vin within this CEM and i can't find it at the typical location :?:
VOLVO CEM_0L01Y_EEPROM.7z
(902 Bytes) Downloaded 108 times
wormland
Year and Model: 2007 XC90
Has thanked: 13 times
Post by wormland »
VIN is located in flash, not eeprom.
oscilloscope
wormland wrote: 16 Aug 2022, 22:13 VIN is located in flash, not eeprom.
opps wrong one then ha , thanks :mrgreen: is that where the abs code is stored too ?
ZRimaZ
Post by ZRimaZ »
You mean ABS (BCM) serial? No. BCM serial is in ECM eeprom as part of immo system
Have a nice day,
ZRimaZ
