P80 Steering wheel compatibility?
Has thanked: 1847 times
Been thanked: 1710 times
My brother in the US has a 97 850 NA SE, and the steering wheel plastic is breaking up now in the CA sunshine.
Can you fit a steering wheel from a 98-00 or later C70 (-04) to and 850? Do you need the matching airbag?
I have a nearly mint steering wheel I can send him from a 99 S70, if they are interchangeable.
Thanks,
Has thanked: 1504 times
Been thanked: 3817 times
It looks like the v70 e fresh in 1998- was a new wheel and airbag…..
Nikolaech
Year and Model: Volvo 850 93
Has thanked: 15 times
Been thanked: 16 times
Post by Nikolaech »
scot850 wrote: 16 Aug 2022, 17:15 I have a nearly mint steering wheel I can send him from a 99 S70, if they are interchangeable.
Thanks,
Are interchangeable. I changed the steering wheel from 850 to S70. The airbag is a little different because of the design. Connectors are the same.
Thanks for the info guys. Looks like he will have to find an airbag as I can't ship that strangely.............!
Nikolaech
Post by Nikolaech »
I don't know your situation. In such cases, we send by passing transport.
The shipping companies don't like shipping airbags! Seen as explosives.
Thanks,
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
Reach out to our friend Robert, I'll bet he has swapped a few - but as the good Doctor points out, the airbag control stuff changed behind the '99 dark times. Pay no attention to the man behind the curtain.
I will ask Robert. The airbag changes were mainly to the way the system was activated from mechanical to electrical.
Haven't had a chance to check Vida yet to see if they are listed as fitting different models.
Thanks,
misha
Has thanked: 152 times
Post by misha »
scot850 wrote: 23 Aug 2022, 08:05 I will ask Robert. The airbag changes were mainly to the way the system was activated from mechanical to electrical...
It's ONLY on SIPS airbags.
Driver's & passenger's airbags were all electronically activated.
But...check '99 & '00 steering wheel airbag if it would work on pre '99...i'm not sure on this.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Nikolaech
Post by Nikolaech »
S70 99 two-stage airbag, no.
S70 99 single, yes.
Technical documentation is not publicly available. If I'm wrong, correct.
