Is that an internal combustion powered bicycle?jonesg wrote: 11 Aug 2022, 17:59 Replaced the leaked tranny fluid, i only measured half a cup when the lower cooling pipe was pulled from the radiator, thats all I put back.
I found it easiest to pump it back in the top cooling hose rather than mess with the dipstick hole.
Pump conveniently threads on the top of a soda bottle, same threads as quart of oil.
never bothered measuring the fluid hot as it shifts fine and i put back the same as came out so...
Don't know how the pic got rotated 90 degs.
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
- 20220817_215817.jpg (84.81 KiB) Viewed 676 times
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
Willber
- Year and Model: 2.4t 2002
- Has thanked: 5 times
Replaced the front and rear hydraulic engine mounts which were the last if the ones to change. I should have done this sooner as it has made a big difference to NVH. The old ones hadn't leaked but were collapsed and cracked and the wire rope was very baggy!
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
[/quote]
Gas-powered stereo.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
yep, infernal combustion engine on a walmart beach cruiser.Krons wrote: 17 Aug 2022, 20:53Is that an internal combustion powered bicycle?jonesg wrote: 11 Aug 2022, 17:59 Replaced the leaked tranny fluid, i only measured half a cup when the lower cooling pipe was pulled from the radiator, thats all I put back.
20220811_112726.jpg![]()
4 stroke, 49cc, conversion kit from bike berry.
- jonesg
use a $12 stethoscope, you can hear it clear as a bell just turning the hub by hand.br0dy519 wrote: 17 Aug 2022, 18:48Is your noise sort of harmonic depending on vehicle speed, with intermittent vibration? I rode in the passenger seat today (is there anything more emasculating than being driven around by your wife?jonesg wrote: 09 Aug 2022, 14:19 I have same noises in my front end, sounds like something rubbing, checked dust shields etc, I think i'll let it ride til it gets unmistakable
or run it on front jackstands and listen with a stethoscope. Haldex fuse is pulled.) and it honestly sounds like the wheel bearing on the passenger side has gone too. Noise increases when braking or putting load on the right side. What a bugger!!!
good excuse to buy another tool too.
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
I’ll try that. If i recall theres a little bit of brake drag noise that impedes my ability to hear anything else with the wheel off. Stethoscope is $7.50 this week on sale! Sweetjonesg wrote: 19 Aug 2022, 08:00 use a $12 stethoscope, you can hear it clear as a bell just turning the hub by hand.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
So hard to tell on those wheel bearings, I just went through this and replaced both of them. FYI I found the best price on FAG's at RockAuto.
2003 XC 70 (sold)
- Has thanked: 987 times
- Been thanked: 1075 times
I broke the shift lock button on my automatic V70. I had repaired it with super glue years ago. I can still shift, but the button hangs out.
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
Well Scot, since you pushed me I took the front bumper skin off todayscot850 wrote: 14 Aug 2022, 19:33 Not really, they had used some clear coat of some sort on them at some point which was a swine to remove. only way to get neat the edges on the XC was to remove them. I took the opportunity to swap all the minor bulbs out at the same time as the 2 that were out could not be removed otherwise. It was when I discovered the RH outer marker light is the only one that rotates counterclockwise to remove!!
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
