Transmission codes
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 250 times
- Been thanked: 77 times
yanga001
- Has thanked: 59 times
- Been thanked: 110 times
This is the second time i know of that a TCU replacement cleared transmission codes. I had it happen on a 98 s70 before which presented with the flashing arrow of death. Glad its resolved!
2008 S60 2.5T Auto (Sold)
- Has thanked: 1846 times
- Been thanked: 1710 times
Wow, glad you got lucky on that one!
hausmeister
Very strange when logic actually fixes something
bought a 2nd one as spare, so long as they are cheap.
I think mine already had issues for some years, as per the points I listed that are working much better now.
850 T5-R '95 auto
Using logic will never work!
It is like common sense. Very rare commodity!
hausmeister
Today I had time to take my faulty TCU apart. I just wanted to see if there is anything obvious.
The only thing I can see is the one big green cap (c602 5.5v 0.022F) might be bulging a little bit. Everything else looks fine to me, but doing anything else than visual inspection is beyond me. Thought maybe someone might be interested in the pics or might have suggestion on how to fix it.
Maybe I'll try and replace all the caps on it... just for fun. It did work fine other than all the TPS related issues.
- IMG_20221113_183746.jpg (547.47 KiB) Viewed 293 times
- IMG_20221113_183739.jpg (564.49 KiB) Viewed 293 times
850 T5-R '95 auto
On a 2000 V70 base I had, I had TCU errors but the issue was corroded/oxidised pins on the TCU. The dealer figured it out after I had spent hours trying to sort it. I could not get Vida to talk to the TCU which should have been a clear pointer to me! Having said that the car still ran fine in my case, it just liked to throw random TCU codes and Engine check light and ABS codes as well.
- misha
- Has thanked: 152 times
- Been thanked: 402 times
That TCU is from '93 model.
T93280138
Since you have a '95 it should at least have T94 or T95.
T93280138
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
hausmeister
I am not familiar with the TCUs. But, when I searched for the model number (P3545864) it seemed to be correct for the T5R. The replacement I got I think is also a T93 and it works so far. I am not saying you are wrong, but does it even matter?
850 T5-R '95 auto
