And get a boost gauge.
More power out of b5254t(this has been done too many times I know) Topic is solved
- Has thanked: 2855 times
- Been thanked: 1332 times
Also note that Lucky went out of business.
So take his advice with a grain of salt.
- Has thanked: 987 times
- Been thanked: 1075 times
swedespeed may have more Volvo moders.
Petskoi
- Year and Model: 1997 V70 awd
Yup, ita cheaper to get a boost gauge, oil pressure gauge and a afr gauge, than it is to rebuild the engine xDmatthew1 wrote: 24 Aug 2022, 16:07 Also note that Lucky went out of business.![]()
Petskoi
This guy is a mad scientist xD wonder if he calculated the airflows to be preferable with the bigger maf etc.matthew1 wrote: 24 Aug 2022, 16:05 Welcome to MVS, Petskoi. Here are some links that may help, food for thought.
19T, but otherwise the overall goal is the same: https://www.matthewsvolvosite.com/how-t ... -v70-fast/
Data, products, opinions:
viewtopic.php?t=51736
viewtopic.php?t=52023
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 112 times
I'm in the process of doing this, but it's not going well because I have somehow built a super16T that flows as much as a 20T
Overflowed the MAF, bent some rods, overflowed the injectors, started knocking again
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
So. When making rockets, it helps to be a rocket scientist?Goupil wrote: 25 Aug 2022, 11:26 I'm in the process of doing this, but it's not going well because I have somehow built a super16T that flows as much as a 20T![]()
Overflowed the MAF, bent some rods, overflowed the injectors, started knocking again![]()
volvolugnutr
Petskoi
The bent rods might be indicating too much boost too low at the rev range. I remember something like it needs to be ~0.7 bars under 3k rpm. Take this with a grain of salt tho, its a "trust me bro" statementGoupil wrote: 25 Aug 2022, 11:26 I'm in the process of doing this, but it's not going well because I have somehow built a super16T that flows as much as a 20T![]()
- Goupil
the bent rods were from me not looking at the data, doing a pull for logs, ran out of MAF unexpectedly so it was running super leanPetskoi wrote: 25 Aug 2022, 13:46The bent rods might be indicating too much boost too low at the rev range. I remember something like it needs to be ~0.7 bars under 3k rpm. Take this with a grain of salt tho, its a "trust me bro" statementGoupil wrote: 25 Aug 2022, 11:26 I'm in the process of doing this, but it's not going well because I have somehow built a super16T that flows as much as a 20T![]()
The second time it started knocking makes no sense, there isnt anything wrong in the datalog
- 808 Views
Last post by - Pete -
- 10 Replies
- 1332 Views
Last post by 454cid
- 30 Replies
- 10090 Views
Last post by hmsky83
- 1805 Views
Last post by precopster
- 22 Replies
- 1918 Views
