Sweet. Thank you
Vida CEM swapping
konielian
- Year and Model: 2010 C70, 2019 XC60
Hello,
I can help you modifying that flash, i have all neccesary data to change and information.
But i have no idea how to write it back to CEM and this is an issue!
If you want you can send me the flash.
Thanks!
Thanks!
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
BaseAdr=FB00005ft24 wrote: 05 Sep 2022, 21:57 using the online disassembler, what do I use for the entry code. I know the MCU is M32C also, do I just select default for Endian?
Thanks
Default endianness.
5ft24
- Year and Model: 2005 XC90 V8 AWD
- Has thanked: 20 times
- Been thanked: 12 times
ODA as M32C, BaseAddr 0xFB0000 and default Endian... Wants to know where to start disassembling... If I tell it to start at the beginning, it comes up with a bunch of "unknown"...
- cem.7z
- 2005 XC90 V8 Dump CEM 30728539
- (112.65 KiB) Downloaded 162 times
flyovr
- Year and Model: 2011 C30
- Has thanked: 2 times
Hey all, been lurking for some time. Cracked my P2 MY07 XC70 last night using Teensy and managed to get a solid CEM bin file. I can read it with a hex editor and am finding my VIN included.T5Luke wrote: 21 Aug 2022, 15:07 If just change config is enough, here a simple extract from my flasher.
Open CEM 320kb bin from CEM MY 2006- and change config. Not so nice but free...
parameter.txt needs to be next to exe and you need to find parameters on your own...
I think it has bugs but it will work...
Sorry, link was wrong, now with parameter file
https://filetransfer.io/data-package/348Y8KBl#link
@T5Luke, Super interested in this config tool. Also noticed you mention its from your flasher. I have been trying to read up through all of the pages of this forum but have gotten lost.
Seems like the 50 user download limit has been hit and was wondering if you could re-up? Looking to change my headlight config to ABL and adjust tire size for speed correction.
Thanks everyone for your work on this. I've always been super interested in the topic but haven't had the time to deep dive into the topic.
Cheers!
07 XC70 with ABL retrofit in works
11 C30 T5 M66 Hilton Stage 2
flyovr
Seems like we are in the same boat! Tried the same but wasn't able to disassemble exactly like you.5ft24 wrote: 07 Sep 2022, 20:39 ODA as M32C, BaseAddr 0xFB0000 and default Endian... Wants to know where to start disassembling... If I tell it to start at the beginning, it comes up with a bunch of "unknown"...
Did you happen to figure out how to flash back to the CEM afterwards? Can't wrap my head around everything at the moment.
vtl
That's ok, as the dump contains both code and data sections. Disassemble the whole file, save to disk. Register at Renesas site, download M32C datasheet, look at the address space map, vectors, start sequence.5ft24 wrote: 07 Sep 2022, 20:39 ODA as M32C, BaseAddr 0xFB0000 and default Endian... Wants to know where to start disassembling... If I tell it to start at the beginning, it comes up with a bunch of "unknown"...
- 9355 Views
Last post by RickHaleParker
- 9346 Views
- 27 Replies
- 28939 Views
Last post by cn90
- 10 Replies
- 10860 Views
Last post by jonesg
- 5975 Views
