Has thanked: 1505 times
Been thanked: 3818 times
brunocerous wrote: 07 Sep 2022, 08:53 Blue Steel ('98 V70 base AT) recently had its coolant light come on after a two-hour drive with two of my kids in the car, but I found a Napa and topped it off.
The right side of the radiator appears to have a leak about one-quarter of the way down. I see replacements with oil cooler ports, but is that only for turbo models? Mine does not seem to have these.
You can use the radiator and ignore the cooling ports, make sure you have the right transmission connections
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Oil coolers were only installed on turbos, however the radiator is 100% compatible with the NA cars. Just leave them disconnected.
The -'98 and the '99+ radiators are different though, so keep that in mind.
Edit- what abscate said! The trans cooler ports also changes in '99.
Has thanked: 1850 times
Been thanked: 1712 times
Thanks guys for catching that last important piece. I had forgotten to add the 98-99 change on the trans cooler side. Were they all changed or was the change for the 00 year on the cars with the 5 speed auto trans, or did they all change in 99?
I think it was a -98, 99/00, and then P2 solution
Pretty sure the transmission hoses for the 99 and 00 are the same part so same fittings
bmdubya1198
The trans cooler lines were all changed for '99-'00. 4 speed and 5 speed use the same lines.
yanga001
Has thanked: 59 times
Been thanked: 110 times
Post by yanga001 »
Would recommend anyone who has the old style spray nozzles (2 hoses) to pick up some washer nozzles from any of these cars. My 98 had the old style and the upgrade is amazing for vision. Much more efficient spray of water.
Changed the front wiper transmission with one from a 2000 V70. seems to be a lot faster on the downwipe. Did the passenger wiper arm upgrade for the drivers side and a good amount more is covered by the blade at the expense of a 1 inch arc at the bottom of the windscreen on the drivers side. Overall worth it.
2008 S60 2.5T Auto (Sold)
bmdubya1198
Those fan-type nozzles are a must!
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 131 times
Post by 454cid »
I swapped to the fan type nozzle, but the Pro Parts version..... I would not recommend. I seem to go though washer fluid very fast. The spray is not high enough on the windshield. One of these days, I'll try something else.... maybe get some from a salvage yard, if I ever go and find a suitable car to pull from.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
You can save $18 with the PPS, or spend $24 for the ones that work.
That song has played so much it’s worn out the bits in the .wav
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
I was gonna have a look at my rear brakes when finding out my wheel sensors need a bit of a cleaning :D
BMW 540i 2002
S70 Base 2000
