so ill try to get all the info i can in here but im sure i will miss something
I own a 1999 v70 GLT pretty much stock.
I have the chance to get a complete 2006 s60R with a bad manual transmission for cheap cheap. from my understanding this is a bt5254t4 engine of the RN engine family.
From what I can gather my 99 v70 is the first of the rn engine family, would this make the swap a simple drop in, motor mounts should line up. But what about engine wiring or the fact id taking an engine that was mated to a manual (awd i assume) to auto FWD?
Being different chassis I dont think i would be able to use any of the AWD components, and being a FWD transmission I dont think i would be able to put my auto tranny into the S60.
Any info would be great i've seen some on swapping an RN engine into a pre-RN chassis but I dont think this would apply to my situation.
bt5254t4 swap in 99v70 Topic is solved
- Has thanked: 1613 times
- Been thanked: 4078 times
That 2006 might be dual VVT and you don’t have an intake VVT drive on your 1999
Confirm cam and crank sensor compatability
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
Sounds like a royal pita. Go to the bone yard and get an older motor fitting your car and just drop it in. I think price for a complete engine is like $400-$500.
Good luck!
Good luck!
BMW 540i 2002
S70 Base 2000
That would get you into swapping to the DIM and immobilized and probably more rabbit holesdonutV70 wrote: 09 Sep 2022, 01:50 Well my thought is that I would use the ecu and wiring harness from the 06. I doubt my ecu would run it well even if all the sensors were the same
ECU are pinned to VIN from 1999 on
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
While both cars are controlled by ME7 engine management, the later ECU would not be plug-and-play in your car. It would require a custom tune to make things work.
As mentioned, the P2R motor has dual VVT, while your '99 P80 turbo had single (EX). The control routine for them is different.
Also, while on the single VVT engines, things will run correctly with the VVT locked out, the cam timing events on the dual R motors is completely different and they do not run properly with the VVT disabled. (Unless you re-clock the cams)
That all said the motor would bolt into your car, using your existing mounts, but the bulk of the work would be in trying to get it wired to run.
The AWD stuff is worthless for you, as is much of the rest of the car.
It sounds like your car is still running, but you're wanting more power?
donutV70
- Year and Model: 1999 V70
- Has thanked: 9 times
My motor is fine, this is just a chance at a better motor and more hp. This would be a project for fun not maintenencekallekula wrote: 09 Sep 2022, 05:58 Sounds like a royal pita. Go to the bone yard and get an older motor fitting your car and just drop it in. I think price for a complete engine is like $400-$500.
Good luck!
donutV70
Chuck W wrote: 09 Sep 2022, 06:35 While both cars are controlled by ME7 engine management, the later ECU would not be plug-and-play in your car. It would require a custom tune to make things work.
Exactly my thoughts on the awd components, my assumption on wiring was if I took the ecu, wiring and ignition system from the p2 then I would be good to go.
So my other option would be to take the auto transmission from my p80 and put it into the p2r which I assume is a no go due to the awd and control modules
donutV70
if this becomes a reality I surely will. I just want to have a better understanding of the wiring and adaptation to have the engine run well in the new chassis.
ARD makes it seem like i just need to block off the second VVT sensor and im good to go, im not sold on it being that easy yet though.
The old ecu would likely run the new engine, but injector duty cycle probably would need scaling as they will be bigger at the least.
Im looking at worst case scenario using the larger turbo off the p2R chassis on my p80 car. people seem to say that an injector and turbo upgrade are easy power, although again I am skeptical that it as easy as just bolting parts on, i assume there would be tuning associated to receive any notable power gains
- 411 Views
Last post by 93SCMax
- 594 Views
Last post by 1998v70xcbill
- 165 Views
Last post by TRNorton
- 1584 Views
Last post by jblackburn
- 704 Views
Last post by vtl
