Hi Steve,abscate wrote: ↑12 Sep 2022, 03:18I’ve got lots of spares of adjusters, but it’s a headlight removal to get these in. Not too bad, three 10mm m6 bolts, as long as they don’t seize .MrAl wrote: ↑11 Sep 2022, 20:38 1998 v70 base non turbo (after $2800 worth of recent repairs)
Hello again,
I went out at night for the first time in months since i could not drive at night for a long time because of the cataracts. Now that that is fixed, i can drive at night although i probably wont need too really.
So i went out to start the car and take the garbage out, and i turned on the headlights and noticed the area in front of the car lit up pretty nice. I thought the headlights needed adjustment but that was just the cataracts it seems. While trying to adjust the headlights the adjustment nut broke on one of the headlights so that killed that idea right away. Apparently though they dont need adjustment so i guess it's ok now even with the nut mechanism broken off. I was going to drive around the block but i can see that the area in front of the car is very visible now even at nighttime, so i'll save it for a time when i really have to go out at night.
Well thanks and i may take you up on that one day but for now it seems they are ok as i tested last night. It just appeared that they may have been adjusted wrong because even with the lights on i could not see that well at night with the cataracts. I can see pretty well at night now it's an amazing difference unbelievable. So i probably will never have to adjust them.
