Fuel pump for 2000 V70XC 9470674
Has thanked: 1836 times
Been thanked: 1709 times
Re: Fuel pump for 2000 V70XC
That makes sense and at least it is a pump that we can use on the AWD's that will hopefully mean no replacement needed for a long time!
Has thanked: 1500 times
Been thanked: 3810 times
I implemented the TI pump into the Kat this week. This took some modification.
It’s a Walbro GRJ444 pump made by TI
The pump sits inside a long plastic tube , and unlike the FWD pump , the seal to the fuel line is accomplished by squeezing a conical sleeve into a silicone receiver in the housing.
The TI pump is slightly longer than the original, so I had to trim the plastic guide snout to rationalize
The sock is slightly different on the bottom, secure with a drop of epoxy on two sides
Wiring plug is different and the case ground is no longer needed. You do need to ground the fuel lines though using the ground lug.
My pump wires had failed at the external connector so I made a through hull wire connector with a piece of CuNiForm and an epoxy plug of about 5 cm to seal
Plan B..one could also figure out how to connect o the tapered output snout of the pump and then run fuel line to direct connect the pump to the metal output line.
TI pump implementation photos, captions to come
bcfischer
Year and Model: 1999 V70xc
Has thanked: 14 times
Post by bcfischer »
V70 XC Pumps are a tough find. AutoHausAZ says that this Walbro is in stock and fits the 2000 XC.
https://www.autohausaz.com/pn/WA-300710606
Query: Does the 2000 XC have the fuel pump with the copper tubes running from the plastic pump housing to the face plate at the top of the tank or does it have the plastic pump housing that goes from the face plate down to the bottom of the tank with a rubber hose from the face plate to the pump module inside of the plastic pump housing?
I have a 1999 XC which has the former style.
Take care and stay safe,
Brian
Brian Fischer
Duluth, Minnesota, USA
late year 1999 V70XC (Chassis 587997)
I believe all the XC and R models use that former style you refer to above
The autohaus link takes you to a wrong pump for a p80 XC or R ( AWD) car. Bit of confusion to clear up , early R cars are FWD, later AWD. The autohaus fitment table is incorrect.
The right pump is here, at $108 2022
https://www.highflowfuel.com/genuine-wa ... 2000-2009/
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
Vintage Radio Shack multimeter !
You're going to force me to casually leave my old Fluke in a pic now.
I think Robert did something similar to his Cincinnati 850T5R when he installed a high-volume pump recently.
