Where is the Throttle Body located?
AP
Year and Model:
Post by AP »
I think I need to clean the throttle body on my 2000 S70 GLT. (Ruff idling when cold) Everywhere I go it only says : " You will see a black plastic cover with a single torx screw holding it down"
Where is it located?
pfeener
Year and Model:
Post by pfeener »
It's mounted on the side of the intake manifold. The hose coming from the bottom of the intercooler plugs into the throttle body.
ssforcey
Year and Model:
Post by ssforcey »
Trying to find out where the throttle body is to clean it. Saw this post but I don't know where ANY of it is. Maybe a pic or diagram if anyone knows where one is located. I will say I DO know where the MAF sensor is as I cleaned it lastnight. Maybe that will help.
Thanks so much,
Sharon
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
On an '02 I don't think there is a throttle body - there is an electronic throttle module.
Which engine do you have?
ssforcey
Year and Model:
Post by ssforcey »
Ummm. There's one under the hood :lol:
I'll check.
ummm 2.4? non turbo? Does that answer your question?
Post by Ozark Lee »
The turbos run the ETM, from VADIS the '02 looks to have a fairly standard looking throttle body, it is on the end of the intake manifold, driver's side. It does appear to be electronically controlled so I am unsure what precautions you need to take. If you post the question in the 01+ forum I'm sure those folks can help.
Here is a picture of it:
