Hi,
I just removed the center console of my 98 s70 t5 manual transmission, and I expected to find the crash sensor visible but did not see it. I got a used Volvo replacement Bosch 9459151. Here are a couple of pictures with the center console removed. Is it under the plastic cover in the picture of the back of the shifter?,
Thanks
1998 S70 T5 Where is the crash sensor located
- Year and Model: Many Volvos
- Been thanked: 75 times
It is under the black plastic case that is just below the two white connectors on the second picture.
Lee,Ozark Lee wrote:It is under the black plastic case that is just below the two white connectors on the second picture.
You are right. Thanks. I was not sure and did not want to keep taking things apart.
Here is a picture I followed the advice here to disconnect the battery and wait for the capacitors to discharge and then replaced the unit.
I bought the replacement part in ebay for under $ 50. Took probably 3 hrs because I did not know where all the screws were.
I had taken the car to a dealer, who diagnosed a faulty crash sensor.
Their estimate was over $1200 to replace it. However they were nice enough to give me the correct part number.
After putting all things back, the car seat heaters work, as the power outlet and the SRS light is off.
timmybdaddyof3
- Year and Model: 1998 V70 T5
- Been thanked: 2 times
and the moral of this story is your time is now officially worth just over $383 per hour
Good work
Good work
- 4050 Views
Last post by precopster
- 4348 Views
Last post by harrelldodd
