vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
vtl wrote: 30 Sep 2022, 17:50 Fixed broken fog lights.
It works!
vtl
Post by vtl »
Rvolvos wrote: 01 Oct 2022, 18:39 Passed the 200.000 miles mark👍.
That was the official end of the engine break-in procedure, and you can raise revs above 2000 RPMs now!
Rvolvos
Year and Model: 2006 xc70
Has thanked: 73 times
Been thanked: 23 times
Post by Rvolvos »
vtl wrote: 02 Oct 2022, 20:19
Great, was getting tired of all the honking on the highway.🤓
2006 XC70 2.5T 238k
2012 S60T6 95k rip
2011 C30 T5 M66 105k Totalled RIP
2006 V70 2.5T 184k RIP
2011 C30 T5 AW55-50SN 99k sold
br0dy519
Year and Model: 2004 XC70
Has thanked: 126 times
Been thanked: 116 times
Post by br0dy519 »
Road trip today from Sandusky ABS light came on and the car started acting weird with both the traction control and shifting. I had the codes read at Firestone for free and it showed passenger front wheel sensor, they referred me to my dealer because of all the other codes on my car :lol:. I verified the torque on the axle bolt and made sure everything else was in place. Wiggling the abs sensor wire revealed that it had play, I wonder if I forgot to tighten that 10mm bolt. I retightened it and was on my way.
04s60 2.4
04xc70 2.5t
vtl
Post by vtl »
br0dy519 wrote: 08 Oct 2022, 15:58 Wiggling the abs sensor wire revealed that it had play, I wonder if I forgot to tighten that 10mm bolt.
8 mm! :)
br0dy519
Post by br0dy519 »
vtl wrote: 08 Oct 2022, 16:28 8 mm! :)
Oops :oops: , I’m bad with fasteners. M10 bolt, 8mm hex head. I should have taken a shop class in high school.
04s60 2.4
04xc70 2.5t
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
I let the 07 S60 2.5T roll down the driveway about 8" so the worn tires wouldn't have a flat spot while it waits for me to address the turbo :D .
weitau
Year and Model: 2004 V70
Has thanked: 7 times
Post by weitau »
I fixed the broken tailgate latch on my newly acquired V70. It would open 1 out of every 15 tries and that would really suck once winter rolls around. So once I got it open, I took off the trim panel with the 4 Torx screws, and pulled the panel off (secured by plastic plugs).
Looking at how the outside lever operates, there is a rod that pushes down on a lever to release the lock. This rod seemed to be too short to be effective. So I found a drywall anchor, cut off the end, and stuck it on the tip of this rod to extend its reach. This seemed to make the tailgate open 1 out of every 3 times.
Lastly, I got some silicon spray with the straw tip. Sprayed the lock mechanism from the inside, on down, to the right of the inside lever in the last paragraph. Now it opens with a satisfying click every time :)
Now for that damm check engine light that came on because I checked the spark plugs...
(10/22 edit: found that the MAF sensor plug was left off, plugged it in and reset - good to go!)
2004 V70 2.4L
weitau
Post by weitau »
Took my V70 in to get new back rotors and pads, thinking that there is a whirling sound coming from the rear end. When my mechanic took off the rotors, he found the parking brake shoes had disintegrated (after 18 years and 135k miles, it's normal, aye?). The local auto parts stores didn't have the shoes in stock, so we put everything back together with the idea of ordering the part online.
We took it for a ride, the mechanic said the whirling sound is from the wheel bearing. As he drove, he turned the steering wheel from side to side while listening for the bearing. The fact that the sound changed while changing directions is a sign that it's the wheel bearing and not the brakes. (nice pro tip!)
2004 V70 2.4L
LoveMy03S80
Year and Model: 2003 S80 2.9 T6
Post by LoveMy03S80 »
Took off the headlamp cover wipers since they didn't work together. One worked consistently one whenever it felt like it. Removed the washer fluid lines that went to.them.
Found out why the bumper cover was never staying on. It's been in an accident sometime before I got it. So I popped the fender piece out from behind the plastic headlight "frame" and it fits better ,so does my head light . Now I have to figure out how to fasten it so it stays in place. .
Painted the trim under my headlights
Replaced the floor mats
Put in a new knob for controlling the heat.
That's all I did today to my 2003 s80.
