Best way to get wiring from front to trunk Topic is solved
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
So I need to run some wiring to / from the trunk, and was wondering if any of you had do this for, say, speakers ( no I'm not doing that ).
I ran a single wire from the engine bay back to the trunk through the center console some time ago, but it was a bit tight keeping it clear of the shifter linkage. And that was only one wire. So I'm thinking of maybe under the interior sill trim, if that's doable. I've never pulled any of that trim out, and I'd hate to break something. And I think behind the headliner is out of the question :wink:
1999 V70 GLT
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 337 times
Post by Chuck W »
Along the sill would probably be fine. That plastic seems to be a little more resilient than some of the other stuff, too.
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
On my wagon I ran a beefy wire for trailer lights from the battery to the way back trunk. A connector and fuse at the battery terminal, then down the firewall and along the bottom until a grommet in the trunk. I zip-tied it every so many inches to other lines or pipes so it can’t move or shake.
Sveedy
Post by Sveedy »
BlackBart wrote: 13 Oct 2022, 20:36 On my wagon I ran a beefy wire for trailer lights from the battery to the way back trunk. A connector and fuse at the battery terminal, then down the firewall and along the bottom until a grommet in the trunk. I zip-tied it every so many inches to other lines or pipes so it can’t move or shake.
I was thinking about that option. Maybe put the wires in some of that plastic loom for added protection. If there are enough tie off points....
1999 V70 GLT
Sveedy
Post by Sveedy »
Chuck W wrote: 13 Oct 2022, 19:50 Along the sill would probably be fine. That plastic seems to be a little more resilient than some of the other stuff, too.
I like the idea of the wires being inside. As long as they're not visible.
1999 V70 GLT
Chuck W
Post by Chuck W »
It would all be under the carpet or behind plastic, so very little chance of seeing it.
Sveedy
Post by Sveedy »
Well it looks like running them inside the cabin will be a pain. The carpet comes up apx 6" from the sill and tucks behind the B pillar trim. And I think I'd need to remove the driver seat as well in order to fish anything under the carpet. So I'm going to look into under carriage routing.
Worst case is I have to run the wire loom tucked up along the fuel lines on the other side of the car.
1999 V70 GLT
bill d cat
Year and Model: 1998 V70 T5M
Been thanked: 7 times
Post by bill d cat »
It's been a few years since I looked, but IIRC the front seat has two carpets and the rear seat has one carpet. With the console out, it should be only a short distance to fish from under the rear carpet to under the rear seat.
I did not do this on the Volvo, but I did fish a wire from front to rear on a BMW and I did not need to remove the seats, just the console.
'98 V70 T5 232K mi., 5-speed manual, 3rd evaporator, 3rd windshield, 7th remote shell, heated velour seats, factory HD suspension, IPD stabilizer bar, Volvo strut tower brace and skidplate, XC grill, E-Codes, V-1, JB Weld, Duck Tape, zip-ties, Mobil-1 since new. Goal: MADE IT to the MOON! (was 221,524 miles at perigee November 14, 2016.)
Has thanked: 1505 times
Been thanked: 3818 times
You can run wires down in the rocker panels without pulling too much carpet
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
I've tucked mine inside the plastic conduit on the driver (left hand) side. Had to lift the carpet and take a few trim pieces off, but wasn't too bad
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
