Crazy clutch pressure plate failure Topic is solved
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
So 2/3rds of this pressure plate failed. (Car was due for a clutch)
'98 V70 NA.
Bad spots at 11 and 3. Should be attached with backing, but they've sheared. Symptoms were a clutch that sometimes would disengage but often wouldn't, car wasn't happy going into gear some days, but wasn't others and got progressively worse.
Has thanked: 1511 times
Been thanked: 3827 times
Up close in the breaks in the pressure plate
Has thanked: 1856 times
Been thanked: 1717 times
Looking at what abscate has highlighted, I have never heard or seen that type of failure. How old was the pressure plate and do you know the brand?
The hole above where abscate has ringed, also looks like something has broken off there as well.
OE clutch installed by Volvo in 6/98
Well, I guess the poor clutch had long passed it's safe working life! May it rest in piece(s)!
wizechatmgr
scot850 wrote: 14 Oct 2022, 18:45 Well, I guess the poor clutch had long passed it's safe working life! May it rest in piece(s)!
That it will be doing =)
Those broken springs hold the pressure plate in position when the clutch is in. It looks like it was floating a bit and gouging up the housing as it moved. Not quite sure what happens when the last of three springs breaks ….😳
