The owner's manual doesn't really give special instructions for reconnecting the car battery except afterward to lock and unlock the doors a number of times with the remote. Yet I've read a number of times about the need to put the key in position II before hooking up the battery cables.
The articles or comments about having the key in pos II mention something to the effect of avoiding damaging some modules. If that's the case, does anyone know how it prevents the damage to the modules and why Volvo didn't include that in the owner's handbook...
Reconnecting a battery...
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
I suspect it is a safety feature more than the theorized component protection. If airbags deploy due to some sort of SRS work being done incorrectly, you’re well out of harm’s way.
I still follow the urban legend religiously and connect it in pos2, but I doubt it is absolutely necessary.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- Been thanked: 4068 times
I believe guru jimmy confirmed the above.br0dy519 wrote: 01 Nov 2022, 22:39 I suspect it is a safety feature more than the theorized component protection. If airbags deploy due to some sort of SRS work being done incorrectly, you’re well out of harm’s way.
AylmerQc
- Year and Model: 2007 XC70
- Has thanked: 62 times
OK, thanks.
I see the subject of replacing the little thermistor in the climated module gets a lot of ink online, some have "suggested" I guess, that it got damaged by connecting the battery without having the key in POs II.
I do hope it's just a myth as I've disconnected/reconnected the battery on my XC70 quite a few times recently, and didn't do the key thing...
- Has thanked: 987 times
- Been thanked: 1075 times
I started disconnecting/connecting battery without the Position II process long before I read about need to use Position II for removal/connection. I have never had a problem ignoring Position II.
I always disconnect negative cable first and connect negative cable last. This process is also recommended on my Mercedes and Smart cars.
- br0dy519
I think that's more of a physical wire break issue that happens when people try to clean out that little vent. I have stock of those if you ever need one.AylmerQc wrote: 02 Nov 2022, 07:09 OK, thanks.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- 654 Views
Last post by Caffeind
- 1856 Views
Last post by jreed
- 10 Replies
- 3803 Views
Last post by mecheng
- 26 Replies
- 2036 Views
- 4501 Views
Last post by JacksonTNTurbo
