Reconnecting a battery...
AylmerQc
Year and Model: 2007 XC70
Has thanked: 60 times
Post by AylmerQc »
The owner's manual doesn't really give special instructions for reconnecting the car battery except afterward to lock and unlock the doors a number of times with the remote. Yet I've read a number of times about the need to put the key in position II before hooking up the battery cables.
The articles or comments about having the key in pos II mention something to the effect of avoiding damaging some modules. If that's the case, does anyone know how it prevents the damage to the modules and why Volvo didn't include that in the owner's handbook...
br0dy519
Year and Model: 2004 XC70
Has thanked: 126 times
Been thanked: 116 times
Post by br0dy519 »
I suspect it is a safety feature more than the theorized component protection. If airbags deploy due to some sort of SRS work being done incorrectly, you’re well out of harm’s way.
I still follow the urban legend religiously and connect it in pos2, but I doubt it is absolutely necessary.
04s60 2.4
04xc70 2.5t
Has thanked: 1505 times
Been thanked: 3818 times
br0dy519 wrote: 01 Nov 2022, 22:39 I suspect it is a safety feature more than the theorized component protection. If airbags deploy due to some sort of SRS work being done incorrectly, you’re well out of harm’s way.
I believe guru jimmy confirmed the above.
AylmerQc
Post by AylmerQc »
OK, thanks.
I see the subject of replacing the little thermistor in the climated module gets a lot of ink online, some have "suggested" I guess, that it got damaged by connecting the battery without having the key in POs II.
I do hope it's just a myth as I've disconnected/reconnected the battery on my XC70 quite a few times recently, and didn't do the key thing...
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
I started disconnecting/connecting battery without the Position II process long before I read about need to use Position II for removal/connection. I have never had a problem ignoring Position II.
I always disconnect negative cable first and connect negative cable last. This process is also recommended on my Mercedes and Smart cars.
br0dy519
Post by br0dy519 »
AylmerQc wrote: 02 Nov 2022, 07:09 OK, thanks.
I think that's more of a physical wire break issue that happens when people try to clean out that little vent. I have stock of those if you ever need one.
04s60 2.4
04xc70 2.5t
93SCMax
Year and Model: 2001 V70 T5 mt
Has thanked: 36 times
Been thanked: 44 times
Post by 93SCMax »
This is the correct way to disconnect/reconnect a battery. Credit Howard's Volvo website.
https://howardsvolvos.webs.com/miscissues.htm#207347288
Archer
Year and Model: 2002 V70/S60 T5
Been thanked: 5 times
Post by Archer »
I forgot to put in position II when reconnecting battery in my 2002 V70 T5...fried the CCM.
AylmerQc
Post by AylmerQc »
Did you need to put in an entirely new CCM or were you able to repair it?
Archer
Post by Archer »
Had to replace it, sourced one from Erie Volvo Parts.
