non oem catalytic converter xc70
porwanabe
Year and Model: 2004 xc70
Post by porwanabe »
2004 xc70. appears though no confirmed yet I need a new converter. Trying to find a NON OEM as prices are stupid silly. Can anyone point me the direction of a NON OEM converter that people have had good luck with.
Thanks
br0dy519
Year and Model: 2004 XC70
Has thanked: 126 times
Been thanked: 116 times
Post by br0dy519 »
Following this as I would like to replace it on my car as well eventually. Hopefully someone chimes in. OEM cat is worth more than the vehicle. Also would like installation tips, looks like a pain.
04s60 2.4
04xc70 2.5t
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
I'm going to weld mine, needs a new flex pipe section.
try this,
https://www.magnaflow.com/products/5147 ... rter-51477
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
I have a Snabb 3" downpipe with cheap Magnaflow converter. The converter itself was like $100 back then. It throws no codes and does not smell.
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
br0dy519 wrote: 02 Nov 2022, 13:01 Following this as I would like to replace it on my car as well eventually. Hopefully someone chimes in. OEM cat is worth more than the vehicle. Also would like installation tips, looks like a pain.
Not sure what condition yours is?
br0dy519
Post by br0dy519 »
$800 USD nearly for a Magnaflow!! WOW Cat prices have doubled in the past 2 years.
04s60 2.4
04xc70 2.5t
jonesg
Post by jonesg »
br0dy519 wrote: 02 Nov 2022, 23:03 $800 USD nearly for a Magnaflow!! WOW Cat prices have doubled in the past 2 years.
hence my decision to buy a mig welder and start practicing with scrap pipe from auto shop dumpsters.
I've got the welding down fairly decent now after some help on welddotcom.
br0dy519
Post by br0dy519 »
My problem isn't the flex as much as the big hanger, nothing is supporting it anymore except a plumbing strap. Don't think there's barely any metal left to weld to.
04s60 2.4
04xc70 2.5t
jonesg
Post by jonesg »
I would fabricate a new hanger and bracket, the cat body is quite hefty and not very difficult to weld.
you'd need to make the hanger and install the exh system so its all aligned, then tack weld the bracket, remove and finish the weld, there isn't much room for anything more than a tack whilst in place.
pay the man or pick up a cheap mig welder and start practicing.
