Hi,
My 2004 2.5T XC90 was running perfectly when I parked it 2 weeks ago in my garage.
When I started it again I noticed a rough idle an some backfire in the exhaust.
Later I got the yellow engine light.
VIDA said Misfire cylinder 1.
When I unplug the cyl 1 coil nothing changes. And when I remove the coil and put a spark plug inside it I get no spark. (I do get some with cyl 2)
I swapped the coils without success. I removed the cable case to inspect the wires and they seem correct. I checked the wires with a multimeter and found no fault.
Any help would be greatly appreciated!
NB: I did a compression test just in case, no problem on the 5 cyls.
XC90 2.5T 2004 No spark cylinder 1
Okay. After a quick search I found out that if I want to replace the ECM I need to buy a used one and have it "cloned" by a specialist.
I see Xemodex of course.
Are there such service providers in Europe?
Many thanks in advance
- RickHaleParker
- Been thanked: 979 times
Disconnect the ECM. Clean the connector and reinstall. A lot of times its just a bad connection.
Active
Past
Past
Hi,
I did several tests today.
- removed the ECM, cleaned the pins and socket with contact cleaner
- checked the wires for cut or grounded wire
- used a frequency meter on the trigger pins
I have no signal on the trigger pin coming on the ECM for cylinder #1: 0 Hz whereas I get about 45 Hz on other cylinders
I guess the ECM is faulty. Yet I read that it is very rare.
Could it be a sensor like the crankshaft position sensor?
- RickHaleParker
Open circuit, with the coil pack disconnected or Closed circuit with the coil pack connected. Thinking there might be something pulling and holding #1 high or low that wound produce 0Hz. Did you check for shorts to that line?Dragoz001 wrote: 18 Nov 2022, 13:44 I have no signal on the trigger pin coming on the ECM for cylinder #1: 0 Hz whereas I get about 45 Hz on other cylinders
Active
Past
Past
I'm not sure I understand your question.
When I unplug the ECM the trigger wire is not connected anywhere, I checked that.
To make really sure I even cut it just after the ECM and there's no signal with my frequency meter.
I had the same idea that the cause is external to the ECM hence in the wiring but no clue for that...
That's why I was wondering is something could cause the ECM to stop triggering that cylinder... like a faulty sensor.
Yet the other 4 cylinders run perfectly.
- RickHaleParker
That is an open circuit. It sounds like something burn out the ECM I/O port for #1. You might be able to drop a new ECM in and go or you may need to have somebody synchronize the ECM with the new CEM. If we can get Yagger to chime he could yell you for sure. He should be able to transfer your software to new hardware. He most likely can do it online if you have a DiCE unit. Only thing is your CEM is a CEM-B. It think he needs to have it on his bench to crack the PIN number. He is in California. Your in Paris ... France? Or is it Paris Texas?Dragoz001 wrote: 19 Nov 2022, 03:20 To make really sure I even cut it just after the ECM and there's no signal with my frequency meter.
Yagger wrote: https://www.datatransferring.com/cem-p2-1999
Active
Past
Past
Okay, we came to the same conclusion.RickHaleParker wrote: 19 Nov 2022, 07:25 That is an open circuit. It sounds like something burn out the ECM I/O port for #1.
Now I fear the same problem could occur again with a new ECM. I've read that some bad coils may do that. The former owner of the car replaced all 5 coils with OEM parts 3 years and 20 000 Km ago...
Yes. I looked for that part used and it's not very hard to find one in Europe even though petrol engines are way less common than diesels here...RickHaleParker wrote: 19 Nov 2022, 07:25 You might be able to drop a new ECM in and go or you may need to have somebody synchronize the ECM with the new CEM.
Some people around here advertise they can clone any ECU, I will call them on Monday.
Er... CEM-B sounds like Chinese to me... yet I guess it's a generation that has some PIN protection in case you want to program it from the ODB2 plug. Am I correct? I have a Chinese DiCE unit.RickHaleParker wrote: 19 Nov 2022, 07:25 If we can get Yagger ... He should be able to transfer your software to new hardware. He most likely can do it online if you have a DiCE unit. Only thing is your CEM is a CEM-B. It think he needs to have it on his bench to crack the PIN number. He is in California. Your in Paris ... France? Or is it Paris Texas?
Actually I'm in France but not in Paris, the system chose that for me... I'm 500Km south of Paris.
Many thanks for the time you spend to help me. I'll keep you informed.
- 9 Replies
- 2859 Views
- 762 Views
Last post by lzy54610
- 16 Replies
- 4441 Views
Last post by shiloh51933
- 2162 Views
Last post by precopster
- 5610 Views
Last post by EanBarnard
