No crank 05 S60
Hotspark
Year and Model: 2005 S60
No crank 05 S60
Post by Hotspark »
I’ve had the cem ecm and key checked. I’ve checked the pins on the connectors and still nothing. I’ve scan the system and I’ve attached a picture of the scan. Any suggestions is welcomed. Thanks
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
You sure the battery is not to low? If it fall below a certain voltage the CEM will not let the starter crank.
Place your finger on the Starter Relay and have somebody turn the key to start position a number of times. Is the relay clicking?
2005_S60_Starting system.png (82.22 KiB) Viewed 153 times
Hotspark
Post by Hotspark »
Thanks for the reply. I’ve got a good hot battery with 13 volts. I’ve been working on this car for a while. When I first got it it would crank and start. But if you turned it off it would restart unless you disconnected the battery. Now it won’t crank at all. The starter relay is not getting a 12volts when the key is turned to start.
Hotspark
Post by Hotspark »
Will a bad UEM keep the car from cranking?
jonesg
Year and Model: 2004 V70
Has thanked: 70 times
Been thanked: 483 times
Post by jonesg »
I'd try a new battery in the FOB.
