850 Mass Air Flow Topic is solved
misha
Has thanked: 152 times
Been thanked: 402 times
Re: 850 Mass Air Flow
Post by misha »
As far as i remember...on Jetronic system...Maf is replaced with just an insert and it's housing is in one piece with airbox.
However....don't go with anything else but Bosch.
Part number should be written on the insert.
https://www.ipdusa.com/products/12610/M ... 220-234380
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
manovlov
Has thanked: 620 times
Been thanked: 143 times
Post by manovlov »
Capture d’écran 2022-12-03 à 21.44.11.jpg (100.5 KiB) Viewed 365 times
I ask the seller to control the serial number of the insert... Could it be possible that the sensor fits to my engine ?
misha
Post by misha »
Bosch or genuine Volvo(which is actually a Bosch)...ONLY!!!
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
foggydogg
Has thanked: 83 times
Post by foggydogg »
manovlov wrote: 03 Dec 2022, 13:24 Capture d’écran 2022-12-03 à 21.44.11.jpgI ask the seller to control the serial number of the insert... Could it be possible that the sensor fits to my engine ?
Mea culpa, I forgot your car is non-turbo.
manovlov
Post by manovlov »
Don't worry, the seller cancelled the sale, he doesn't have the right tool to remove the sensor... I have no other way than to go to Volvo or Skandix.. I was near the goal...
Capture d’écran 2022-12-04 à 00.03.09.jpg (90.64 KiB) Viewed 331 times
misha
Post by misha »
Sensors are not interchangeable.
They use different method to measure the air flow...hot film vs.thermistor if i recall correctly.
Different voltage output.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha
Post by misha »
Looking closely at the insert...it could be possible that inserts are the same...but you will need to compare part# from the inserts itself...not housings.
However...the chances are pretty low.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
manovlov
Post by manovlov »
Thanks Misha...
Has thanked: 1506 times
Been thanked: 3822 times
You remove those security torx with a bit with a small home in it, or a ViceGrip !
You can also Dremel the pin off in 17 seconds
manovlov
Post by manovlov »
abscate wrote: 04 Dec 2022, 04:28 You remove those security torx with a bit with a small home in it, or a ViceGrip !
I prefer to use the right tool.
