As far as i remember...on Jetronic system...Maf is replaced with just an insert and it's housing is in one piece with airbox.
However....don't go with anything else but Bosch.
Part number should be written on the insert.
https://www.ipdusa.com/products/12610/M ... 220-234380
850 Mass Air Flow Topic is solved
- misha
- Has thanked: 152 times
- Been thanked: 402 times
Re: 850 Mass Air Flow
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- manovlov
- Year and Model: 1995 850 GLT 2.5 170
- Has thanked: 620 times
- Been thanked: 143 times
I ask the seller to control the serial number of the insert... Could it be possible that the sensor fits to my engine ?
- IMG_4046.jpg (195.38 KiB) Viewed 353 times
- misha
Bosch or genuine Volvo(which is actually a Bosch)...ONLY!!!
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- foggydogg
- Has thanked: 83 times
Mea culpa, I forgot your car is non-turbo.
- manovlov
Don't worry, the seller cancelled the sale, he doesn't have the right tool to remove the sensor... I have no other way than to go to Volvo or Skandix.. I was near the goal...
- misha
Sensors are not interchangeable.
They use different method to measure the air flow...hot film vs.thermistor if i recall correctly.
Different voltage output.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Looking closely at the insert...it could be possible that inserts are the same...but you will need to compare part# from the inserts itself...not housings.
However...the chances are pretty low.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 1506 times
- Been thanked: 3822 times
You remove those security torx with a bit with a small home in it, or a ViceGrip !
You can also Dremel the pin off in 17 seconds
- 16 Replies
- 4936 Views
Last post by christylee26xs
- 13 Replies
- 9683 Views
Last post by jimmy57
