Have you tried using hardware like IOT terminal to read & write the ecm , of course if its covered by that?dikidera wrote: 03 Dec 2022, 15:30 I actually did. Dumping them was easy(the internal on-chip rom and external flash of the ecm) from the Hilton commands. It's writing that is the core issue. You need your own code to run on the IC, but at the same time, satisfy the condition as to not reset the chip.
Vida CEM swapping
oscilloscope
- Year and Model: 2005
- Has thanked: 27 times
- Been thanked: 11 times
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
IO terminal can, and does in fact support all the things I wanted to do, write+read of CEM,ECM(basically anything with a SH7055 chip) as well as immobilizer stuff. Like I said, everything, all the bells and whistles.
However as you might expect, it's paid and not cheap. I am not a fan of black boxes, I always want to know HOW something works.
oscilloscope
I did figure it was something along them sort of lines ,dikidera wrote: 04 Dec 2022, 14:35 IO terminal can, and does in fact support all the things I wanted to do, write+read of CEM,ECM(basically anything with a SH7055 chip) as well as immobilizer stuff. Like I said, everything, all the bells and whistles.
I know exactly what you mean.
I have all them tools for my job. Yes they do the job quickly and right.
To add.
I am currently working trying to create a script for the iprogpro which can perform the volvo synchronization's, Yes, they are already available but i want to do my own , although failing badly , as the IDE's native help section is in Russian which is not my first language.
But try and try I must!
I totally understand.
oscilloscope
No synchronisation is kind of like a subaction when the key is turned. The cem - ecm-abs module all have to be ",in sych" , if they are not the car will not start and throw up a immo fault. But it's not a immo fault.dikidera wrote: 04 Dec 2022, 15:29 Is the synchronization the practice of coding in a new ECU in the CEM? Thats what my google FU revealed at least.
In regards to what I do from time to time , is to take a dump from the cem eeprom & the ecu eeprom , and have the abs serial and then marry them all together.
In regards to the later cars which would probably carry the sid807evo. There was a synchronisation software avaliable but it has been withdrawn by the company codecard. The most latest cars I don't know if they still use the same synchronisation method. it maybe something else.
dikidera
Well, as I said, it's the first time I've heard of that, so I am not familiar and have no idea what it entails.
What I do know is that with the help of a member(not sure if he would like to be mentioned) who was kind enough to provide me with a SBL copy I managed to run my own little kernel.
A little fun fact is that Volvo were not fully experienced with Denso? Their watchdog function was called manually and interspersed in the whole code, rather than using a timer interrupt. Well, whatever, these are events from 15+ years ago, the world was a different place back then and Denso was used only a few years.
Code: Select all
void main(void) {
UBC.UBCR.BIT.UBID = 1; //disable UBC
MSTCR.WRITE = 0x3C04; // disable H-UDI(not sure if needed but did either way
WDT.WRITE.RSTCSR = 0xA500; //disable WDT
WDT.WRITE.RSTCSR = 0x5A00;
volatile int t = WDT.READ.TCSR.BIT.OVF; //again not sure if needed, going by the docs
WDT.WRITE.TCSR = 0;
while(1)
waitn(WAITN_CALCN(55000)); //56300 microseconds is the upper limit at which our Port B needs to be toggled to satisfy the external watchdog so we go with a more conservative 55000.
PB.DR.WORD ^= 0x8000; // 1:1 from Subaru.
oscilloscope
It's cool no worries.,dikidera wrote: 06 Dec 2022, 16:55 Well, as I said, it's the first time I've heard of that, so I am not familiar and have no idea what it entails.
A little fun fact is that Volvo were not fully experienced with Denso? Their watchdog function was called manually and interspersed in the whole code, rather than using a timer interrupt. Well, whatever, these are events from 15+ years ago, the world was a different place back then and Denso was used only a few years.Code: Select all
void main(void) { UBC.UBCR.BIT.UBID = 1; //disable UBC MSTCR.WRITE = 0x3C04; // disable H-UDI(not sure if needed but did either way WDT.WRITE.RSTCSR = 0xA500; //disable WDT WDT.WRITE.RSTCSR = 0x5A00; volatile int t = WDT.READ.TCSR.BIT.OVF; //again not sure if needed, going by the docs WDT.WRITE.TCSR = 0; while(1) { waitn(WAITN_CALCN(55000)); //56300 microseconds is the upper limit at which our Port B needs to be toggled to satisfy the external watchdog so we go with a more conservative 55000. PB.DR.WORD ^= 0x8000; // 1:1 from Subaru. }
That's whats this you have created ? , what does it ment too do ? Also the comment in the code that has H-UDI , maybe it was HUDI I'm sure I have seen that in a renesas book or programmer somewhere
oscilloscope
Very cool , out of curiosity does the denso ecm have a renesas mcu? I would try and satisfy my curiousity but i can't check while on holiday.dikidera wrote: 07 Dec 2022, 03:09 It was a simple test to see what I needed to do to get the kernel running without interruption.
- 9770 Views
Last post by RickHaleParker
- 10030 Views
- 27 Replies
- 30965 Views
Last post by cn90
- 10 Replies
- 11760 Views
Last post by jonesg
- 6804 Views
