br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
gnalan wrote: 09 Dec 2022, 13:02
vtl wrote: 09 Dec 2022, 12:39 Any plans?
I have a Mustang now.
I think he meant what are you doing tonight, going out for drinks? :lol:
04s60 2.4
04xc70 2.5t
gnalan
Year and Model: 2001 S60
Has thanked: 557 times
Been thanked: 135 times
Post by gnalan »
br0dy519 wrote: 09 Dec 2022, 13:07 I think he meant what are you doing tonight, going out for drinks? :lol:
Taking the kids to see Santa, then driving around to look at Christmas lights. :)
Been thanked: 4071 times
What’s the name of your Mustang?
gnalan
Post by gnalan »
abscate wrote: 09 Dec 2022, 15:47 What’s the name of your Mustang?
I don't name my cars. I never have.
DonnVa
Year and Model: 2005 XC70
Has thanked: 21 times
Been thanked: 61 times
Post by DonnVa »
I replaced the big front and back engine mounts on my XC70. I noticed a huge improvement in the vibration in my steering wheel while in gear and at idle. It feels like a normal car again. I had previously replaced the torque and right engine mounts. Note- if you reference the FCP YouTube video, I could not get the front mount out after unbolting it without taking out the radiator fan and taking it out the top. It just would not slide around anything to get it out the bottom. Probably the difference between the S60 and XC70.
2005 XC70 Cross Country 2.5T 185k miles
1962 122s 4dr 100k+ TMU
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
30 + other cars and trucks
Suddenly realized I never replaced the weak battery on the P2 from last February. It’s dated 2014. It’s working well in 20F weather but it’s going to sit upstate, so it will get a trickle charger install
Hmmm, this is trickier on the P2 with rear battery...
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Procured a set of door panels to for swapping. Removed window switches for cleaning and lubrication besides cleaning of the door cards. Use the bent fork to reach the inside tabs of the winder buttons for removal, cleaning and lubrication with dielectric grease. Ran a bead of sealant, will dry clear for any potential squeaks at the top.
Not the exact color but the fabric does help blend it in from what I can tell so far by placing the panel next to the seat.
Has thanked: 2207 times
Been thanked: 1852 times
On the P2 there should be a +ve and -ve connector under the hood for jump starting the car. I keep meaning to check these out for trickle charging as otherwise it means jamming the cable in the rear door seal or feeding a cable through a window which again is not ideal.
If you look at the engine bay picture on this thread:
viewtopic.php?t=83619
If you look between the box on the top right marked 'Fuses' and the strut brace there is a +Ve sign on the plastic. Why can't you connect to that and the ground on the engine. I can't recall if on the P2 the top torque mount has a ground wire running to the firewall like on the P80. On my P80's I connect the ground to that ground bolt and the +ve directly to the battery +ve. Will that not work because if you can jump the car from there why can't you charge from there?
Rolled out of Williamstown with Caitlin at 0400…. :o
Horrific rain and wind down through CT, 0730 ferry cancelled.
Drove through NYC, no traffic!
Stopped halfway to put muffler back on new hangar
:D
Krons
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
scot850 wrote: 17 Dec 2022, 18:45 On the P2 there should be a +ve and -ve connector under the hood for jump starting the car. I keep meaning to check these out for trickle charging as otherwise it means jamming the cable in the rear door seal or feeding a cable through a window which again is not ideal.
I've ran battery chargers a couple time under the hood on my P2s. No issues. I connect the positive to the post under the flap below and ground to nearby post connected to the chassis.
08 C702.5T (sold)
The non-Swedes:
