Right sounds cool,dikidera wrote: ↑12 Dec 2022, 14:22It depends. I use socketCAN and a can utility called cansend and do 000FFFFE#FF86000000000000 and the linux socket can driver takes care of communication via MCP2515
Ah you mean what the command does? It tells all the controllers(ECU,TCM,AEM whatever) to stop sending can commands and enter programming mode.
although I do believe that on one part of this thread ,there was a mention about programming mode can only be entered at a certain point in the starting routine it's super early. , I'm definitely messing up the exsplaintion there, but that may be the reason it keeps restarting??
