So there are 3 different boot part numbers, with 2 different inner part numbers? Did you get a GKN part number for the EMPI equivalent or is it NLA now? I thought they were all the same or are the shafts a different diameter?
If I recall correctly you can fit a turbo axle on an NA but not the other way around. My memory may be wrong on that but don't think so.
1998 v70 NA M56 CV boots
- Has thanked: 1856 times
- Been thanked: 1717 times
Re: 1998 v70 NA M56 CV boots
- Has thanked: 1509 times
- Been thanked: 3827 times
Correct. On the -1998 NA m56 three different boot part numbers
They change in 1999
No GKN number yet, for the driver side inner.
They change in 1999
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
So sorry you have to use Empi.
If Empi is the only option, I would stock up on them or have a rebuilt axle available as you will likely be changing the boot every 6 months or so.........!
Managed to beat back winter to get the shafts installed and car back in her feet.
Got bitten by two things
An hour wasted looking for one of the three 36 mm sockets I own, unsuccessfully
The new circlip in the shaft bit me in the BEE hind by not popping in. I’ll have to redo that side
On the M56 at least , you could punch out a stuck axle from the other side
Fighting winter ……
Fighting winter ……
- 71F7DE87-78B3-4674-90F9-9154DE7FC253.jpeg (624.19 KiB) Viewed 187 times
- 00C06C07-BA50-4E60-814A-ADCA3139D2D7.jpeg (520.4 KiB) Viewed 187 times
- 46DC16C0-34D2-4CFD-85AC-F2B1D728D90C.jpeg (577.66 KiB) Viewed 187 times
- A07307BC-4D50-4E9B-A4BA-00B2B2FAB3DD.jpeg (801.73 KiB) Viewed 187 times
- A4BCD9AC-A193-4FEC-8A4B-D4C5BD1DAB16.jpeg (570.27 KiB) Viewed 187 times
Are you re-using the same axles, the ones with the new boots fitted, or are you using other axles? If you are using the originals, did you change the circlip or are you re-using the old ones? I have had issues over the years with clips, especially aftermarket ones. I only use Volvo clips which I believe you can still get. Also, try using a little trans oil on the splines especially when it is cold to try to get momentum on the cold steel.
454cid
- Has thanked: 145 times
- Been thanked: 131 times
I don't know how you do it. You must be part polar bear... or penguin, or something that likes the cold. I hate it. Having said that, I may be pulling an engine in the coming weeks, outside.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
