98-00 AWD Fuel Pump/Sending Unit Assembly.
Looking for one that's not working, not holding pressure, or was replaced because of a check valve problem. This is just for me to take apart and explore, so not really wanting to spend a fortune.
Shipping to California. Thanks!
WTB: 98-00 AWD Fuel Pump/Sending Unit Assembly. Prefer one that doesn't work. Topic is solved
- Has thanked: 1500 times
- Been thanked: 3812 times
I think I’ve got one from a replacement. Will adviserrres wrote: ↑17 Apr 2022, 11:08 98-00 AWD Fuel Pump/Sending Unit Assembly.
Located from a 99 XC70abscate wrote: ↑17 Apr 2022, 13:09I think I’ve got one from a replacement. Will adviserrres wrote: ↑17 Apr 2022, 11:08 98-00 AWD Fuel Pump/Sending Unit Assembly.
Pm me for logistics
Jonesroad
- Year and Model: 2015 v60
- Has thanked: 13 times
just curious what did you find?rrres wrote: ↑17 Apr 2022, 11:08 98-00 AWD Fuel Pump/Sending Unit Assembly.
rrres
- Year and Model: 1999 v70XC
- Has thanked: 10 times
- Been thanked: 26 times
Thanks for the offer. I know these are getting hard to find.
I was able to pull one from the local junkyard. I've seen two or three other AWD Volvos listed in junkyards in the past, but they were somewhat farther from me. It would've been a half day trip just to pull the pumps. Not worth it.
Would have been great if I got one that is known to have failed. Anyway, I'm going to take this one I just got apart. Obviously, being from the junkyard, I don't know the history of the pump. This pump might be in good working order.
My hypothesis is that the o-rings and rubber parts in the sending unit are, more likely, what causes the leak and fuel pressure drop rather than the internal check valve.
It's blowby
I’m not sure there is a check valve. I didn’t see one taking this apart
rrres
The check valve is integrated in the outlet nipple as shown in the example picture. I was able to confirm this by blowing into the nipple and couldn't blow air into it. When I sucked air through the nipple, it would flow.
What I'm thinking is that a fuel system that doesn't hold pressure (after eliminating the injectors, fuel line leaks, fpr, etc) doesn't necessarily mean a bad fuel pump check valve, Most likely it'll be the o-rings, and rubber parts in the sending unit.
It's blowby
Maestrours
- Year and Model: 03/2000 V70 XC 2.4T
- Has thanked: 29 times
- Been thanked: 9 times
Hello,
Did you go further in your investigations?
I took apart my fuel sender after seeing Rob DIY video about failing o ring but I did not see any trouble, as far as I can say.
My issue is an immediate loss of fuel pressure after turning off the engine.
Thanks
Cyril
Thanks
Cyril
