'98 V70 T5 tires - size matters?
5rivers
Year and Model: V70 1998 T5
Been thanked: 14 times
Post by 5rivers »
Greetings all,
All four wheels have 195-60R-15's but this model V70 calls for 205-55R-16's. Can I run the car on the 15's - does this mess anything up - or should I be looking for 16" rims and tires?
Appreciate your feedback!
5rivers
1998 V70 M56, silver/grey, has tranny issues, #?# owner, 330,xxx miles, a handy parts car
1998 V70 AT, nautical blue, 2nd owner, 260,000 miles, Sold
1998 V70 AT, T5, forest green, 3rd owner, 172,300 miles, Mimas 16" rims
Has thanked: 1856 times
Been thanked: 1717 times
If your car is running on 15" rims then you ca continue to run them. Just check they are not hitting the front calipers. It could be the car was originally sold with the optional 'big brakes' (302mm v's 280) rotors. Those do not fit under 15" rims if I recall. If it is running the 280mm front rotors you should be good. Some like to run the 16" rims in summer for better grip/stability with the wider tire foot print, and then use 15" in the winter with the taller sidewall on steelies as they can take a bigger hit from rough surfaces.
It will not screw anything up as the rolling diameter is the similar on these 2 tires. There is about a 1.5 mph difference at 65 mph. Originally the 16" tire was a 50 sidewall which gives the exact same speed at the 195/60/15 tire. But due to complaints in the uS of people claiming they were getting blow outs when hitting pot holes they increased the recommended sidewall from 50 to 55 on 16" rims.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
5rivers wrote: 14 Jan 2023, 08:09 Greetings all,
You can stay with those but if you go with 16" the 205/55/16 may rub a little. Per Neil the OE calls for 205/50/16. The rubbing could be due to the 07 S60 2.5T rims I put on our 00 S70, having an offset of 49mm rather than the stock 43mm of 15" rims.
https://www.wheel-size.com/size/volvo/v ... 2000/usdm/
MDK
Year and Model: 2004 S60R
Been thanked: 41 times
Post by MDK »
Well, I took a set of the 2003 AWD wheels from an S60 and put them on a 1998 XC70 , cleared everything.. 215-45-r17.. for every tire size you go up or down it changes the speedometer by 1.5 miles an hour.. give or take.. but so what.. my XC70 looked awesome! MDK
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
https://www.discounttire.com/learn/tire-size-calculator
https://tiresize.com/comparison/
Tire Rack has similar information.
Circumference is the important number here; there may not be a large impact on your speedometer because of the difference in the aspect ratio. No harm otherwise. Issues usually only crop up when going bigger, or changing to wheels with different backspacing.
If the tires on it now have good tread and don't slide around a bunch with dew on the road, run'em.
MoVolvos
Post by MoVolvos »
MDK wrote: 14 Jan 2023, 19:04 Well, I took a set of the 2003 AWD wheels from an S60 and put them on a 1998 XC70 , cleared everything.. 215-45-r17.. for every tire size you go up or down it changes the speedometer by 1.5 miles an hour.. give or take.. but so what.. my XC70 looked awesome! MDK
Wondering if the XC70 is taller up front as the THOR is compatible with the S70's. The 215 though wider is not as tall as the 205/55/16. Regardless the OP is good with his current 15". From other online post 215/45/17 should be the largest before a little rubbing takes place especially if the springs are worn.
https://volvo-wheels.com/product/volvo- ... -thor-rim/
Volvo Thor.png (617.9 KiB) Viewed 1037 times
Volvo 16 vs 17 Tires.png (546.13 KiB) Viewed 1037 times
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
scot850 wrote: 14 Jan 2023, 10:15 Just check they are not hitting the front calipers. It could be the car was originally sold with the optional 'big brakes' (302mm v's 280) rotors. Those do not fit under 15" rims if I recall. If it is running the 280mm front rotors you should be good.
Is there an easy way to visually identify the 302 mm vs 280 mm front brakes? My 1998 T5 has 16" on it but I'd like to swap on 15" temporarily. According to FCP, the caliper is the same for both but the bracket is different. Looking at the 280 mm and 302 mm, all I see is the cylindrical protrusions look longer on the 302 and the inner face is more angular. Any easier way to tell?
FireFox31
Not really that I know other than measuring the diameter of the rotor. Looking at the 2 brackets below (assuming they are showing the correct ones) the ends of the brackets do look a little different in terms of length. If you can tell from that then ok. If not it is a case of pulling a wheel and measuring the rotor diameter.
https://www.ipdusa.com/products/9263/30 ... 319-120644
https://www.fcpeuro.com/products/volvo- ... 50-8251156
MoVolvos
Post by MoVolvos »
FireFox31 wrote: 15 Jan 2023, 16:37
My 98 S70 T5 came with 16" and I went with 01 V70 15" for a softer ride. Best to throw them on and spin the wheel. Most 15" have less positive offset so less likely to rub the calipers.
98 S70 T5.jpeg (216.68 KiB) Viewed 980 times
Has thanked: 1509 times
Been thanked: 3827 times
5rivers wrote: 14 Jan 2023, 08:09 Greetings all, :D :D :D
Just checking back with you 5rivers.
In the middle of moving , so let me know if you need parts , which will mean I don’t have to move them.
:D :D :D
