I am in Sloans lake area, Edgewater area.
I've been trying to find a good diagram to check all the vacuum lines.
850r failing emissions miserably (HC and CO) Topic is solved
- Has thanked: 1850 times
- Been thanked: 1712 times
Did you check under the hood? Volvo used to have a sticker on the hood with the vacuum layout.
There are thumbnail pictures that you can expand on this thread from Volvo Forums website:
https://volvoforums.com/forum/volvo-850 ... ion-68636/
JayPea44
- Year and Model: 2007 xc70
- Has thanked: 36 times
- Been thanked: 5 times
It is there, but a little small and torn up, thanks for the link!scot850 wrote: ↑25 Jan 2023, 14:49 Did you check under the hood? Volvo used to have a sticker on the hood with the vacuum layout.
- Clemens
- Has thanked: 473 times
- Been thanked: 219 times
One more thing: if you are not getting full boost, you might have a badly worn turbo, split intercooler hoses (check carefully, they might look okay if not boosting) or a shot intercooler.
Usually it's the hoses, but I had a badly worn turbo in my 94 and you could smell the overly rich exhaust gases when stomping on the loud pedal.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Donor: 1995 854 10V
JayPea44
Thanks I'll check them out. I'm not too concerned right now unless it's causing or contributing to these issues. This old thing is a project so the turbo and associated system si going to get overhauled in the long run either way.Clemens wrote: ↑25 Jan 2023, 15:12 One more thing: if you are not getting full boost, you might have a badly worn turbo, split intercooler hoses (check carefully, they might look okay if not boosting) or a shot intercooler.
- Has thanked: 2656 times
- Been thanked: 1248 times
They actually pulled the red/yellow/green/blue line one from MVS... I made (color coded) that probably 17 years agoscot850 wrote: ↑25 Jan 2023, 14:49 Did you check under the hood? Volvo used to have a sticker on the hood with the vacuum layout.
viewtopic.php?t=6941
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
Just to add, If you don't know when your TCV was replaced, they are known to fail and cause erratic turbo behavior. Or any of those vacuum lines being split will reduce boost.Clemens wrote: ↑25 Jan 2023, 15:12 One more thing: if you are not getting full boost, you might have a badly worn turbo, split intercooler hoses (check carefully, they might look okay if not boosting) or a shot intercooler.
Knows enough to be dangerous
- Has thanked: 1505 times
- Been thanked: 3818 times
Note that red in Matt’s diagram doesn’t match the red on the Volvo diagram. Mark them with tape on your car before you pull them off
- BlackBart
- Has thanked: 927 times
- Been thanked: 884 times
You made that?! Funny, I used that, I have it printed in color in some folder somewhere! I even used colored hoses! (Makes it so much easier to see where you’re going)
JayPea - I also followed advice to tape and mark hoses first. It’s dark and hard to see and covered with grime back there.
I had some funny stumbling long ago, did a tuneup, thought I’d just look over the vac hoses....and they were dry, cracked, splitting. Ran perfectly with new hoses.
We had a cracked intercooler case once, and it stumbled and coughed and spewed black smoke and got single digit mileage while we limped it home. (We hit a big bag of onions in the dark that had fallen off a semi - no sh!t.)
