Restoration: I Bought the Cheapest Running 98 V70 T5M (2023)
- Has thanked: 316 times
- Been thanked: 531 times
Yeah, I wish these systems had a bleeder screw of some type. It would make things much easier!
I finally wrote “ coolant sensor “ on top of my p80 reservoirs because I got tired of sending my broken ones back to FCP for replacement
Nice 426 Silver I believe, just like the “Kat”
I wish I had that cool hood pop up, we lost that in 1999
Only about 100 T5M brought into North American in 1998, so that car is getting hard to find
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
Looks like it's solid enough to build a fun driver out of.
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
Haven't actually checked the paint code yet. According to the title and the PO, a foundation bought 6 identically spec'd V70's. I'm now the 3rd legal owner.abscate wrote: 27 Jan 2023, 01:11 I finally wrote “ coolant sensor “ on top of my p80 reservoirs because I got tired of sending my broken ones back to FCP for replacement![]()
My 1999 S70 had the same popup hood.
Apparently the low coolant light does work, or it started working this morning anyway.
Still waiting to hear if I can get a ball seat for the shifter.
Car has a bad stumble coming off of idle under load. I think next job will be a tune up. PO said ignition was over due. Also going to need to get some tires. Has 255/65 R16s off of an XC and they rub too much when cornering. I can feel my bank account getting lighter by the minute.
Knows enough to be dangerous
As in the 90 degree hood opening? All P80s have that after '99 too.abscate wrote: 27 Jan 2023, 01:11 I finally wrote “ coolant sensor “ on top of my p80 reservoirs because I got tired of sending my broken ones back to FCP for replacement![]()
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
My 99 S70 doesn't seem to do that. I was disappointed because I think that idea is absolutely fantastic after using that feature on my 96 850.bmdubya1198 wrote: 27 Jan 2023, 08:45
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 987 times
- Been thanked: 1075 times
Mercedes had the 90 degree opening hood since about 1980's. They needed it since the big grills were attached to the hoods.
- Has thanked: 2199 times
I thought all P80's had the wide opening hoods. Now I will have to go check my 00 R. 454cid, can you post a picture of your hood hinges?
- WhatAmIDoing
Come to think of it. The 2000 XC70 I robbed parts off of had the 90 degree hood hinges.scot850 wrote: 27 Jan 2023, 12:33 I thought all P80's had the wide opening hoods. Now I will have to go check my 00 R. 454cid, can you post a picture of your hood hinges?
Right, I've never seen a P80 that didn't have them. Check your hinges, you should have these tabs that you can rotate.
- Screenshot 2023-01-27 201928.png (963.92 KiB) Viewed 917 times
