WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
Since I lost my old serpentine belt tensioner tool, went to the farm supply store to make another one. 39 cents out the door. Is that a new record?
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
^ Pic ?
1999 V70 GLT
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
454cid wrote: 29 Jan 2023, 11:30
bmdubya1198 wrote: 29 Jan 2023, 07:37 Woah, saffron S70? Where did you find that? Must have either been imported or painted.
Were only Saffron V70's imported to North America?
The only cars in North America that were sold in saffron were the 1998 V70R and 1998 C70 coupe. Europe got an S70R for '98, available in saffron. I believe it was available on other P80s too over there, but not here.
WhatAmIDoing
Sveedy wrote: 29 Jan 2023, 17:31^ Pic ?
Couldn't get a 3/4" bolt and my angle grinder is taking an extended vacation in someone else's toolbox, so had to add washers.
brunocerous
Year and Model: 1998 V70
Has thanked: 284 times
Been thanked: 36 times
Post by brunocerous »
One short drive to take a kid to school in the T5, and it would crank, no-start for a good 10 minutes, followed by misfire codes. A couple of long drives later, it had no problem starting.
Then I noticed I’d lost a wheel bolt somehow.
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
WhatAmIDoing wrote: 29 Jan 2023, 16:19 Since I lost my old serpentine belt tensioner tool, went to the farm supply store to make another one. 39 cents out the door. Is that a new record?
I made mine from a gearbox plug removal tool that has a 19mm spanner (wrench) size
ST1 copy.jpg (94.35 KiB) Viewed 352 times
ST2 copy.jpg (115.23 KiB) Viewed 352 times
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
Has thanked: 1502 times
Been thanked: 3817 times
brunocerous wrote: 29 Jan 2023, 19:07 One short drive to take a kid to school in the T5, and it would crank, no-start for a good 10 minutes, followed by misfire codes. A couple of long drives later, it had no problem starting.
Nice Perfos , Bruno. I’ve got spare bolts if needed
If you are up to date on ignition parts, I would have look at the engine coolant temperature sensor, visual on the pins in the connector and the cold temperature ohm reading.
Table here for the 1998
brunocerous
Thanks for the offer! I could swear I took some wheel bolts off the XC70 I ended up using for parts.
Last night, I ordered the Bosch distributor cap and rotor, plus new wires. The plugs are new, as of about 1,000 miles ago.
I'll also need a coolant system refresh (hoses, thermostat, sensors, heater core) in the coming months. The previous owner had the timing belt done about 20k miles ago, so I'm wondering if I should redo it along with the water pump while I'm draining the coolant anyway.
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
Hi,
Took the car out on a drive first time in many 2 months now. Went to the dollar store about 1.2 miles away.
Doesnt sound like much, but after all the problems i have been having it's a milestone.
Had to replace a lot of stuff mostly ignition stuff.
Ran pretty smooth all the way. Hope it stays that way.
Also updated my car telemetry. Now it automatically logs the battery voltage 24/7 and i can read it from inside the house. That's a milestone too been thinking about doing that again for a long time now. Next i will probably add the temperature from inside the car or maybe engine compartment. That will allow me to log the voltage, temperature, and date and time stamp.
Was also wondering if other people would be interested in such a device with wireless remote measurement of the battery voltage 24 hours a day 7 days a week.
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 129 times
Post by 454cid »
MrAl wrote: 30 Jan 2023, 10:31 Hi,
I like dollar stores. I pick up cleaning supplies from them, like sponges, and scrub brushes, and a few cleaners, like LA's Totally Awesome from Dollar Tree. I've also gotten something from Dollar General.... Mean Green, I think. The cleaners often get used for cleaning up car parts in prep for reassembly. I don't like working with dirty parts.
I'm glad to hear the car ran well.
That sounds interesting. I don't think I have a reason to do it myself, but I'd appreciate hearing the way you're doing it... the nutshell version would be fine, as the details are probably more complicated than I'd understand.
I finally decided I better shovel the hood of the 850 off, and get my battery charger/maintainer connected, so that's what I did to my Volvo today. I should have measured the voltage before hand, but I didn't think of it...power locks worked, so the battery isn't dead. I used my new extension cord out to the car, that I bought for the purpose. That vinyl insulation sure is stiff at 21F.
I think I may spray something on the top of my 850's engine. I noticed a bit of white corrosion on the "valve cover" today. I'd guess it's because while sitting the moisture isn't being driven off. I'll have to decide what to use... might go with some sort of aerosol oil, but some sort of dressing/protectant might work too. Maybe even a spray wax?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
