1999 V70 Oblong holes on wheels
Emilyland99
- Year and Model: 1999 V70
Is it okay to use with with oblong holes?
- 54367696-EA16-4DF6-B088-B73AEA004089.jpeg (670.06 KiB) Viewed 308 times
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 131 times
I'm assuming you mean uni-lug rims that are designed with oblong holes. I have my doubts since our Volvos use lug bolts, and not lug nuts. The lugnuts used on uni-lug rims are a shank design and use oblong washers. Our Volvo lug bolts are tapered, and would not be suitable for a washer underneath. I have no idea if the proper lug bolts for a uni-lug rim is something that's made.
Here is Summit Racings page on uni-lug rims: https://help.summitracing.com/app/answe ... -wheels%3F
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 1853 times
- Been thanked: 1712 times
I would strongly recommend against suing these on any vehicle. They look like someone has modified them, probably as they have a vehicle with a different stud pattern to make the fit. That is the dumbest and dangerous thing I have ever seen!
Junk those rims!
Junk those rims!
454cid
Oh wow, there was no picture when I replied..... that is not uni-lug. That does look modified (poorly). Look for new rims.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 1506 times
- Been thanked: 3820 times
I think they have been run loose and have hollowed out. If the lugs tighten to 100 ft lbs I might use them in the back but would not use them on the front
- Has thanked: 927 times
- Been thanked: 1002 times
I veto using them if they do not have good, uniform, round holes on the front side that the lug bolt can fit tight. Over size and out of round bolt pattern will not center well on the hub, places bending stress on the bolts, and may work loose. I don't trust them for anything.
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
They're junk now. Wouldn't use unless super desperate and only on the back.
Knows enough to be dangerous
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 126 times
Precisely this is my guess. I had something similar happen when a certain large lube chain neglected to torque my bolts sufficiently but insisted the torque sticks are sufficient for yield. They are, if it's their mother's car, but not if it's your car. Suffice it to say they now check each wheel with a legitimate torque wrench and often find that the torque sticks for whatever reason aren't doing the job. Maybe they're cheap ones, maybe worn out, maybe they're oil fouled, I don't know...
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
Could be okay? Prop the wheel off the ground with two chairs flat on the tires face up. Take the nuts or bolts and insert into each hole. Turn the nut or bolt and see if it spins freely without shifting side to side. Also, use a flash light from the front to check if you see uneven gaps on the back side. If the nut or bolt spin on center you maybe fine.
The nut or bolt puts pressure on the wheel and the center bore is what carries the horizontal loading and keeps the wheel center. Even if one of the nut or bolt is slightly off, if you evenly tighten the other ones, the one that is slightly off will create some uneven pressure on wheel but not enough to warp or create a balancing issue. Of course this is without seeing it firsthand so you have make an educated guess where all the parameters are at. Worst case take it to the local tire shop and see what they think.
- MoVolvos
*wizechatmgr wrote: ↑04 Feb 2023, 22:17Precisely this is my guess. I had something similar happen when a certain large lube chain neglected to torque my bolts sufficiently but insisted the torque sticks are sufficient for yield. They are, if it's their mother's car, but not if it's your car. Suffice it to say they now check each wheel with a legitimate torque wrench and often find that the torque sticks for whatever reason aren't doing the job. Maybe they're cheap ones, maybe worn out, maybe they're oil fouled, I don't know...
The problem is very few of these people have had a good physics class, understood the material and then are able to apply it. You can't torque each nut individually to 100 ft lb. It needs to be applied gradually and evenly. By the time the last one is on, the first would be over-tightened. If the torque stick is working the torque wrench will checkout but the question is how over tighten are the first one or two? If they are not using the star pattern the torque is more uneven.
- 9 Replies
- 1598 Views
Last post by benrk
- 207 Views
Last post by securisign
