Center Console Creaking Reduced
velorider
- Year and Model: 2005 S60 T5
- Has thanked: 2 times
- Been thanked: 26 times
My '05 S60 center console creaks a lot. I removed it this weekend to fix the issue with the shiftier not stay in drive, i.e. falling into manual mode. I tighten all the torx screws inside the center console, there are about 12, about 1/4 to 3/4 of a turn. This is old plastic so don't go crazy. After reinstalling it, a lot of the creaks went away. I think over time the screws get a little loose, enough to allow the plastic to slightly side against each other causing the creaks. This isn't a miracle cure for all creaking of the center console, but a lot of the road vibration creaks went away.
- 12 Replies
- 4270 Views
- 1487 Views
Last post by BlackThunder
