Has thanked: 1846 times
Been thanked: 1710 times
It is possible it could crack if over-tightened. How soft is the lower hose? I have found that if you re-use hoses when changing radiators or any connection, they sometimes won't re-shape to the new connector and can bunch, stretch or just not shrink to the new connection.
PITA I know, but only way to find out is to drain the radiator and remove the bottom hose the check both sides of the union for issues.
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
brunocerous wrote: 11 Feb 2023, 13:40 I found coolant weeping from Blue Steel’s lower radiator hose. I tried changing the worm-drive hose clamp with a new one, which slowed it, but there’s still a slight leak. I wonder if the replacement Nissens rad has a crack at the lower hose port.
If possible I always try to slice away the portion of any hose where the old hose clamp use to be. As long as the tension, due to the shorter length of hose is minimal it should be fine.
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
I never have luck getting the rubber hoses to not leak. So I always end up buying silicone hoses. They seem to shape, seal, and reseal well.
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
Has thanked: 1504 times
Been thanked: 3817 times
Dr Oetiker to the Rescue
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Yeah, the hose is probably too soft if you didn't replace it already. Time for a new one!
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
went to check the oil before inspection tomorrow....
Good thing I had a spare, I take that as a sign I should do the 99+ dipstick upgrade
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
ZionXIX
Has thanked: 64 times
Been thanked: 194 times
Post by ZionXIX »
Is the 99+ dipstick constructed differently?
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 129 times
Post by 454cid »
99+ upgrade? I like the dipstick on my 96 better. I haven't directly compared the two, however. I can't say exactly what's different between the two. The 96 is orange, and I think the 99 is red like what you show. I think the steel part is different somehow.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Goupil
Post by Goupil »
The 99+ have two O-rings, which means the tube isnt full of condensation all winter :mrgreen:
You have to replace the dipstick and tube as they are both different from the -98 version
454cid
Post by 454cid »
I bought some brake pads I don't need immediately, because of price.... I found Akebono front pads on clearance at Rockauto and bought the last set. With shipping, and the spring retainers I spent about $21. The first set I bought, I spent triple that at FCP, and then used them on the S70 out of necessity, when I intended them for the 850.
I notice Akebono has two lines, "Euro" and "ProACT". The FCP pads I think are the Euro line, and the discount pads I just bought are the ProACT, but I'm not sure it's anything more than marketing.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
