upDATE5: 99 s70 silver awd turbo auto PARTS fs (bulk too), Antlers OK Topic is solved
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Re: UPdate2: 99 s70 silver awd turbo auto for PARTS ONLY, Antlers OK
Post by foggydogg »
weste46 wrote: 22 Feb 2023, 06:59 Is there a throttle body for sale? I have a '00 V70 2.4T with the dreaded ETS warning light on.
He has the front of the car apart so should be able to see the label, anyway. Try PM'ing, he responded pretty quickly to me about a couple things.
CIK7
Year and Model: 95 854T & V70trailer
Has thanked: 328 times
Been thanked: 87 times
Post by CIK7 »
abscate wrote: 22 Feb 2023, 03:22 I started a Milgram ship thread in Classfieds to see if we can get that rear axle from Antlers to Hide Park, NY
Does that mean mvs members along that route will be playing piggyback with it? Like i ship it to someone like June, then from her to someone else, etc?
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
CIK7
Post by CIK7 »
Abscate I've ran into a hexa problem also known as the Allan screws that join shaft to rear differential. I tried a 6mm too big. 5.5mm to small. 1/4" too big. Next one down too small. Will you accept it if I cut the shaft close to the diff? Someone is bound to have the right tool.
Has thanked: 1851 times
Been thanked: 1712 times
It is 6mm. Just make sure it is clean inside the head as it may be either your socket is off size or it is not fully seating. I have a 3/8" drive 6 mm hex and use a wobble shaft to allow the socket to sit square. If the trans is still in or the parking brake is still connected you can use either to control the shaft from moving.
CIK7
Post by CIK7 »
Magneti Marelli Xemodex ETM. Zoom in on pic below.
CIK7
Post by CIK7 »
Test
CIK7
Post by CIK7 »
Package with thumbs up 👍
CIK7
Post by CIK7 »
Antlers USPS receipt for ETM. 🙂 Be sure to download image for later reference.
weste46
Year and Model: 2004 XC70
Has thanked: 3 times
Post by weste46 »
Thanks for that! Glad I finally found an updated ETM!
foggydogg
Post by foggydogg »
CIK7 wrote: 23 Feb 2023, 11:33 Abscate I've ran into a hexa problem also known as the Allan screws that join shaft to rear differential. I tried a 6mm too big. 5.5mm to small. 1/4" too big. Next one down too small. Will you accept it if I cut the shaft close to the diff? Someone is bound to have the right tool.
My suggestion when trying to peddle parts would be to avoid cutting anything if you can help it. The driveshaft has some value as well. Those fasteners were installed with some Swedish version of locktite, a little Gentle heat might help, along with the usual juice of preference. They are metric.
