He has the front of the car apart so should be able to see the label, anyway. Try PM'ing, he responded pretty quickly to me about a couple things.
upDATE5: 99 s70 silver awd turbo auto PARTS fs (bulk too), Antlers OK Topic is solved
- foggydogg
- Has thanked: 83 times
- Been thanked: 402 times
Re: UPdate2: 99 s70 silver awd turbo auto for PARTS ONLY, Antlers OK
- CIK7
- Has thanked: 329 times
- Been thanked: 87 times
Does that mean mvs members along that route will be playing piggyback with it? Like i ship it to someone like June, then from her to someone else, etc?
- CIK7
Abscate I've ran into a hexa problem also known as the Allan screws that join shaft to rear differential. I tried a 6mm too big. 5.5mm to small. 1/4" too big. Next one down too small. Will you accept it if I cut the shaft close to the diff? Someone is bound to have the right tool.
- Has thanked: 1853 times
- Been thanked: 1714 times
It is 6mm. Just make sure it is clean inside the head as it may be either your socket is off size or it is not fully seating. I have a 3/8" drive 6 mm hex and use a wobble shaft to allow the socket to sit square. If the trans is still in or the parking brake is still connected you can use either to control the shaft from moving.
- CIK7
Magneti Marelli Xemodex ETM. Zoom in on pic below.
- 20230223_222114.jpg (237.35 KiB) Viewed 521 times
- 20230223_222132.jpg (219.5 KiB) Viewed 521 times
- CIK7
Test
- CIK7
Package with thumbs up
- 20230224_121625.jpg (341.58 KiB) Viewed 496 times
- CIK7
Antlers USPS receipt for ETM.
- 20230224_124522.jpg (318 KiB) Viewed 482 times
- foggydogg
My suggestion when trying to peddle parts would be to avoid cutting anything if you can help it. The driveshaft has some value as well. Those fasteners were installed with some Swedish version of locktite, a little Gentle heat might help, along with the usual juice of preference. They are metric.CIK7 wrote: ↑23 Feb 2023, 11:33 Abscate I've ran into a hexa problem also known as the Allan screws that join shaft to rear differential. I tried a 6mm too big. 5.5mm to small. 1/4" too big. Next one down too small. Will you accept it if I cut the shaft close to the diff? Someone is bound to have the right tool.
