First, i am from Denmark so perhaps some words come out wrong.
I have some problems with my volvo 2.4t from 2000.
Idle is rolling from 750 to 850.
Voltage in idle is jumping up and down even with the alternator disconnectet.
The sparkplug timing is jumping up and down from 30btdc to 0 btdc.
The problem only occures and gets worse as the engine heats up..
Perfect idle and so on when its cold.
If i disconnect positive cable from alternator its the same.
Changed the starter, did not change anything
Any ideas?
Camshaft and crank sensor is new, 02 sensors working. Maf and map sensor new.
Throttle is working as it should, pefect readings on the tester
Thanks
V70 2.4t 2000 idle and voltage
Had some time to look more in to it..
Had a bad vvt valve...
No fault codes.
Put when driving and accelerating i had no movement on the cam regulation..
Changed the valve and the idle is now perfect and also the spark timing..
No fault codes.
- 4854 Views
Last post by hans747
- 10 Replies
- 4733 Views
Last post by FreeFlyFreak
