SOLD - C70 (2006 and up) Sirona 17”x7.5” Wheels Topic is solved
Krons
Has thanked: 193 times
Been thanked: 202 times
Post by Krons »
I’ll get pictures added to the thread when I get access to the wheels again. Bought this set knowing clearcoat needed redone then found one of the wheels had a crack on the inner lip. Ended up going a different direction with aftermarket wheels. Google Volvo Sirona 17 for specs.
Two are good condition. One needs clearcoat redone. One needs crack fixed and clearcoat and paint touch up redone. Would take $150 plus shipping for all of them.
Located in Des Moines, Iowa.
08 C702.5T (sold)
The non-Swedes:
Krons
Post by Krons »
08 C702.5T (sold)
The non-Swedes:
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
2006 - 2013 - Lug Nut
Assuming it's the 08 C70. Will have the P1 or many if not all P3 Center Bore / Hub Bore: 63.4 mm
1997 - 2005 - Lug Bolt
Center Bore / Hub Bore: 65.1 mm. Same as the P2's.
All bolts or lugs are M12 with differing pitch but makes no difference. OE Fitment is dependent on Center Bore, Offset and Width, the last 2 having some flexibility. You can always use a larger center P2 rims with Hub Rings for P1 so there is some flexibility but not P1 rims to P2 car.
https://www.wheel-size.com/size/volvo/c70/
Hub ring link for reference only. Have never used before.
65.1mm OD to 63.4mm ID Black Plastic Polycarbonate Hub Centric Rings
(www.amazon.com/Circuit-Performance-Plas ... B01JN0O670)
Krons
Post by Krons »
Good catch BKM, I added these are 2006 and up.
Still seeing if I can find a welding shop locally who will do aluminum and I might refurbish as a project. Too many other project though…
08 C702.5T (sold)
The non-Swedes:
MoVolvos
Post by MoVolvos »
Krons wrote: 05 Mar 2023, 20:04 Good catch BKM, I added these are 2006 and up.
My thoughts lately. Hope the warmer weather will motivate me to do a little more and take on more :roll:.
Krons
Post by Krons »
Sold these locally on Craigslist. Got $100 as clearcoat was shot and the crack on one lip. Buyer mentioned JBWelding it…I hope if he sells them the buyers do a close inspection.
08 C702.5T (sold)
The non-Swedes:
