I’ll get pictures added to the thread when I get access to the wheels again. Bought this set knowing clearcoat needed redone then found one of the wheels had a crack on the inner lip. Ended up going a different direction with aftermarket wheels. Google Volvo Sirona 17 for specs.
Two are good condition. One needs clearcoat redone. One needs crack fixed and clearcoat and paint touch up redone. Would take $150 plus shipping for all of them.
Located in Des Moines, Iowa.
SOLD - C70 (2006 and up) Sirona 17”x7.5” Wheels Topic is solved
- Krons
- Has thanked: 193 times
- Been thanked: 202 times
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- Krons
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
2006 - 2013 - Lug Nut
Assuming it's the 08 C70. Will have the P1 or many if not all P3 Center Bore / Hub Bore: 63.4 mm
1997 - 2005 - Lug Bolt
Center Bore / Hub Bore: 65.1 mm. Same as the P2's.
All bolts or lugs are M12 with differing pitch but makes no difference. OE Fitment is dependent on Center Bore, Offset and Width, the last 2 having some flexibility. You can always use a larger center P2 rims with Hub Rings for P1 so there is some flexibility but not P1 rims to P2 car.
https://www.wheel-size.com/size/volvo/c70/
Hub ring link for reference only. Have never used before.
65.1mm OD to 63.4mm ID Black Plastic Polycarbonate Hub Centric Rings
(www.amazon.com/Circuit-Performance-Plas ... B01JN0O670)
- Krons
Good catch BKM, I added these are 2006 and up.
Still seeing if I can find a welding shop locally who will do aluminum and I might refurbish as a project. Too many other project though…
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- MoVolvos
My thoughts lately. Hope the warmer weather will motivate me to do a little more and take on more
- Krons
Sold these locally on Craigslist. Got $100 as clearcoat was shot and the crack on one lip. Buyer mentioned JBWelding it…I hope if he sells them the buyers do a close inspection.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
